| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#3165 |
Drives: 2016 scion frs
#3166 |
Would a 225/40r18 fit on a scion frs in all four corners without rubbing?
Sent from my E6853 using Tapatalk |
#3167 | |
#3168 |
Drives: '13 BRZ 6MT Limited GBS
Hey what's going on guys. I currently have 18x9.5+38 wheels sitting in my house and I was wondering if rocking 255/35/18 all around would cause any fitment issues? I'm sitting on full stock suspension right now.
#3169 |
Drives: 2013 Scion FR-S in White
That's wide. Look up the tool on the forum that shows fitment and you can compare to stock so you don't go too big or too small
| The Following User Says Thank You to HuntingtonFRS For This Useful Post: | the_comedian312 (06-29-2016) |
#3170 | |
The tool said I'd be good on stock suspension so I'm gonna go ahead and mount them up today. Sent from my iPhone using Tapatalk |
#3171 | |
Mount them, lower the car, and stick your phone up there and take a video/pic and decide for yourself if you feel that clearance is enough for you. Every car is slightly different with alignments etc, so no real way to know for sure unless you try it. |
#3172 | |
Thanks for the help man I'll be sure to check it out Sent from my iPhone using Tapatalk |
#3173 |
Drives: 13' SWP Voltech Supercharged BRZ
I'm dropped on RSR Superdown Springs on stock suspension. I'm curious to know whats the best specs on wheels i could run? Looking to possibly do 18's maybe 17s? Please help a n00b :]
#3174 | |
Looks (subjective) Cost (relative) Performance (objective??) Pick two. And in order if importance. |
#3175 | |
Looks wise, track inspired(RPF1, NT03) Cost under 2k Objective as a daily driver, don't want anything to aggressive but would like it to be flush with the RSR Superdown springs Thanks in advance Sent from my iPhone using Tapatalk |
#3176 | |
18x9.5 +38 won't fit or are dangerously close to rubbing on the front strut. Higher offsets would fit but you would probably need a 5mm spacer. |
| The Following User Says Thank You to swarb For This Useful Post: | Jaydemm (07-06-2016) |
#3177 |
Drives: Scion FR-S
Looking for help with tire sizes.
I have 18x8.5 +35 wheels for the front and 18x9.5 +35 for the rear. Also, I'm on stock height. If some of you could help me with suggestions on what size tires I should get I'd be very appreciative. |
#3178 |
Drives: SC BRZ
about to install some coils w/ front camber and throwing a new wheel setup on-
17x9 et~20 all around. the fitment tool shows they should be right at fender but haven't seen anyone run this setup yet. 215/45's up front, 225's out back. any experience? |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
