Old 07-07-2016, 01:08 AM   #365
gramicci101
Off Topic
Originally Posted by zc06_kisstherain View Post
how? i cant move up because there is no room
There was space around the transmission to lift the bottle up. The diff was more awkward, but I was still able get a little bit of an angle to allow the bottle to drain.
The Following User Says Thank You to gramicci101 For This Useful Post:
jarnojvv (07-07-2016)
Old 07-07-2016, 04:02 AM   #366
jarnojvv
jarnojvv's Avatar
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
Change your manual transmission fluid ASAP!!!
Definitely possible, did trans & dif, only used motul bottle nozzel
-JvV-
jarnojvv is offline   Reply With Quote
Old 07-07-2016, 05:06 PM   #367
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
drain whole bottle? i could drain only half or 3/4
not impossible i just meant to whole bottle to drain with using just nozzle
Old 07-07-2016, 05:13 PM   #368
gramicci101
Off Topic
I actually have to change mine this weekend; I'll try to get pics.
Old 07-19-2016, 02:24 PM   #369
zc06_kisstherain
Drives: SWP BRZ
get update with pics if you changed
Old 07-19-2016, 02:44 PM   #370
gramicci101
Off Topic
I haven't yet. I'm still working up the motivation to work on my car in 100 degree heat. Although I'll need to get under it this weekend, so I'll get it done.
zc06_kisstherain (07-19-2016)
Old 07-19-2016, 02:54 PM   #371
zc06_kisstherain
Drives: SWP BRZ
true..
i changed mine at 90 degree...
Old 07-23-2016, 01:05 PM   #372
gramicci101
Off Topic
Here you go. For the transmission, the bottle fits nicely up alongside the transmission. Massage the fill tube to get any kinks out and give the bottle small squeezes to assist with the filling process. It shouldn't need to be said, but put the fill tube in the hole before you raise the bottle. Also, put the fill tube in the actual fill hole and not the gap in the fins just in front of the fill hole. It's kind of embarrassing to pour brand new transmission fluid down the side of the transmission and all over your arm before realizing that you're a dumbass.
The diff is more difficult, especially with the newer, more square bottles. You can't really get the bottle up above the fill port until it's mostly empty and you can crush it a little. Get it as high as you can and squeeze it pretty hard to force the fluid up and out. Once that doesn't work anymore, squish the bottle up in front of the axle shaft and keep going. It's ok if you wad the bottle up to get it up there, because you'll be throwing it out anyways. It isn't a 100% solution, but it's good enough. You can always unscrew the tops of the bottles to transfer any remaining fluid into the next bottle.
The Following 5 Users Say Thank You to gramicci101 For This Useful Post:
DocWalt (07-24-2016), jcw99 (07-23-2016), mwjcyber (07-24-2016), strat61caster (07-26-2016), zc06_kisstherain (07-24-2016)
Old 07-23-2016, 10:03 PM   #373
jcw99
Drives: swp mt '14 brz premium
Very helpful--thanx a lot. I've yet to see the bottom of my car.
jcw99 is offline   Reply With Quote
Old 07-24-2016, 09:40 AM   #374
zc06_kisstherain
Drives: SWP BRZ
i did it very similar but probably i got newer bottle.
i wish they just use standard cap so we can use pump
Old 12-06-2016, 06:43 PM   #375
Silverfrs86
Drives: Silver Ignition 2013 frs
Well i used amsoil in my transmission and i must say i am disappointed because its pretty much the same as before only slightly smoother once its warmed up but now i cant downshift from 3-->2 i have to force it in... It was actually smoother down shifting with the oem fluid and just fyi i have the rear perrin shifter bushing and the whiteline transmission mount insert installed.
Im probably gonna try pentosin or redline mt-85 or mtl still not 100% sure yet because of the different grade from 75-90
Sent from my LGMS631 using Tapatalk
Silverfrs86 is offline   Reply With Quote
Old 12-07-2016, 11:59 AM   #376
gravitylover
Just a quick FYI - Last time I was at the Subaru dealer I stopped at the parts counter and asked, the fluids are now available in 1 liter bottles for ~$10 each rather than just the very expensive gallons they had it in before.
Harbor freight has simple fluid transfer pumps for about $10 so that should make it easy to use to drain the bottle without doing crazy gymnastic moves
Old 12-07-2016, 01:15 PM   #377
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Pay close attention to the transmission fluid Subaru will sell you...I bought some and it was GL-5 rated. Maybe they're now also selling the correct Toyota fluid (LV 75W GL-3), but the last time I bought the Toyota stuff, it was ~50 bucks/liter.
The Following User Says Thank You to venturaII For This Useful Post:
Decay107 (12-07-2016)
Old 12-07-2016, 02:12 PM   #378
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
This.
Subaru tried to sell me their "Extra-S" when I went in asking for transmission oil. It's GL-5 and will fuck your transmission good.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
venturaII (12-07-2016)
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 03:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 08:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 11:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 07:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
