View Poll Results: Do you have the described AT issues?
Yes, but I've ignored them 41 34.17%
Yes, TSB fixed it 14 11.67%
Yes, dealer fix did not help 12 10.00%
No everything is fine 53 44.17%
Voters: 120. You may not vote on this poll
Old 07-07-2016, 04:48 AM   #183
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by FRSBRZGT86FAN View Post
Damn, I have the flash file on my computer right now by the what its a cuw format, I figure if you have techstream illegally you may be able to flash it yourself not sure. You'd have to follow the latter part of this process after page 12:
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=186999
If you have techstream you may be able to flash it with a Tactrix cable, similar how you can do logging, etc with techstream via the Tactrix cable. If you send me the CUW I'll see if I can execute it. I won't flash because my car doesn't have an issue.
Old 07-07-2016, 12:42 PM   #184
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Here it is:
https://drive.google.com/open?id=0By...DA1TDhzZUZPUkk
If you could attempt it that'd be great the paperwork I found online seems really quite simple and applies to most Lexus Toyota and scion vehicles so I hope it applies here: https://www.google.com/url?sa=t&sour...wBZIE0bByLHkRg
I no longer have a techstream cable or tactrix cable for that matter so I can't attempt it
Old 07-08-2016, 12:49 AM   #185
FRSBRZGT86FAN
Do you think techstream pirated version even include that update wizard?
Old 07-08-2016, 02:40 AM   #186
Wayno
Wayno's Avatar
It includes the wizard, whether it works or not without the application being registered is the issue. It seems like it won't work.
Maybe try taking the file direct to a dealer or anyone else with techstream.
Old 07-08-2016, 12:17 PM   #187
FRSBRZGT86FAN
Thanks for trying though. Is your ini file all edited and everything?
http://blog.obd365.com/2014/12/15/ho...tration-error/
Old 07-25-2016, 03:08 PM   #188
Reamer
Drives: 2015 FRS
Originally Posted by azynneo View Post
so if you have an aftermarket tune / FI then you'd have to flash back to stock? What about those with injectors / fuelpump that are aftermarket
I'm curious about this as well. I don't think my car would like it if I flashed back to stock ECU.
Sent from my ONE E1005 using Tapatalk
Reamer is offline   Reply With Quote
Old 07-28-2016, 05:02 PM   #189
FX86
finally forced the dealer to check my tcm and make sure it has the updated software version
the service advisor kept on telling me to take the car out for a test drive to try to replicate the issue..i kept telling him that it happens randomly and not so easy to replicate..just check the freaking tcm...skip all the other troubleshooting routes
then he comes to me and say there is an updated version and we will install it
no automatic shifting issues anymore
The Following 2 Users Say Thank You to FX86 For This Useful Post:
Borrowed Time (08-14-2016), FRSBRZGT86FAN (08-14-2016)
Old 08-17-2016, 12:34 PM   #190
Borrowed Time
Drives: 2015 Ultramarine FRS
Took mine in yesterday to get this update done. I don't even know if I have the idle issues but definitely the hard/rough shifting issue when going into Sport mode after driving in normal mode for a while. Got fed up with it on the other night coming home. Told the dealer that I had the idle fluctuation issue along with the rough shifting that I had told them about last year when I went for an oil change. I gave them the printed TSB and asked them to do the update. Took about 10 minutes explaining how it is intermittent and only happens after driving for a while in normal mode so he would understand....not sure it was being processed by the service writer. The TSB came out after my last visit so wasn't aware at the time. Maybe I shouldn't have mentioned that I had the rough shifting but thought that might put them over the edge on any hesitation....well, maybe it did. They performed the update and told me that they couldn't duplicate the problem, blah, blah, blah. I asked whether they did test drive before they did the update....he wasn't sure....duhhhh. My fall back was going to be that the TSB talks about the idle fluctuation being after driving 25 miles....were they going to drive 25 miles....if so, I'm going with them. Didn't happen and the update was done so hopefully, the problem is solved. Seems ok on the short trip home last night. Will report and vote later when I know for sure whether problem is solved. What I don't get is why the TSB doesn't mention rough shifting or any of the other issues that seem solved in this thread. Thanks for posting this thread and the TSB's on the other.
Borrowed Time is offline   Reply With Quote
Old 08-18-2016, 01:01 PM   #191
Astral Abyss
Drives: 2016 Halo FR-S
It should take care of all your problems. I haven't had a single hard shift or idling issue since I had the reflash done. Car is better than ever.
Astral Abyss is offline   Reply With Quote
The Following User Says Thank You to Astral Abyss For This Useful Post:
Borrowed Time (08-18-2016)
Old 08-23-2016, 11:28 PM   #192
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
9 months or so since the update and ZERO hard shifting issues. If anyone has doubts, just ask them to do it, even if you have to pay labor, it's WELL worth it for the benefits of not having a major annoying headache when trying to enjoy the car.
V_86 is offline   Reply With Quote
Old 08-24-2016, 03:32 AM   #193
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
No luck here in getting the dealer to do it. I give up since the Toyota dealership here in Hawaii is not part of Toyota USA. I even brought a copy of the TSB. Hoping my next car isn't a Toyota.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 08-24-2016, 07:08 AM   #194
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Would anyone know what the labor cost would be roughly? That's the route I want to take and just get it done with.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 08-24-2016, 07:16 AM   #195
Cole
Not a troll
Cole's Avatar
.5 to a full hour, probably.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
soulreapersteve (08-24-2016)
Old 08-24-2016, 09:41 PM   #196
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
What Cole said.
I was told 2 hours but that was probably a guesstimate. They did mine in less than an hour, most of that time was probably the dude cruising around in my car.
The Twins make me smile
AT Transmission Hard Shifting MechEGR Issues | Warranty | Recalls / TSB 95 05-21-2017 11:54 AM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 06:17 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 12:13 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
