Old 06-28-2016, 01:08 AM   #85
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
No more pedal dance?
Trac Off now turns off the brake LSD for M/T.
In previous models (up to 16MY), the brake LSD function was ON (enabled) even during VDC OFF mode, which often caused interference during sporty driving. To avoid this from 17MY, the brake LSD function has been turned OFF (disabled) during VDC OFF (Mode 4) for 6MT models.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
The Following User Says Thank You to Freude am Fahren For This Useful Post:
Stang70Fastback (06-28-2016)
Old 06-28-2016, 01:22 AM   #86
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Not sure if this was already posted or obvious, but since I saw so many people making speculations on how the extra 5hp came about...
"The higher power output has been achieved mainly through a combination of reduced pressure
loss and optimized intake efficiency (inertial effect on the intake).
 Reduced pressure loss:
changed the shape of the exhaust system, change d the shape of the air cleaner case and
boot, improved the intake element
 Optimized intake efficiency: changed the shape of the intake manifold "
Oxyg3n is offline   Reply With Quote
Old 06-28-2016, 01:48 AM   #87
ryoma
ryoma's Avatar
there has been a few times where I was oversteering on the track and I thought that I could control it until at the end where my car just instantly loses control. I wonder if having the VSC/TC fully off (pedal dance) would have affected anything. or I just suck at counter steering lol
Old 06-28-2016, 02:32 AM   #88
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by SuperDave View Post
No. The rs 1 paint is called sunrise yellow.
Its actually called Yuzu, not sure where sunrise yellow came from.
But yes, if you get the paint code (which will be out eventually) any paint shop should be able to repaint your car that color or any other color you want
Old 06-28-2016, 06:01 AM   #89
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
under scion yes, it was yuzu, but under subaru it's called sunrise yellow.
http://www.subaruxvforum.com/forum/a...se-yellow.html
http://www.toyotareference.com/scionfrs
now back to what i was saying, it's a different yellow.
SuperDave is offline   Reply With Quote
The Following User Says Thank You to SuperDave For This Useful Post:
funwheeldrive (06-28-2016)
Old 06-28-2016, 06:06 AM   #90
SuperDave
SuperDave's Avatar
Originally Posted by Poodles View Post
/facepalm
Paint CODE =/= paint NAME
Red: BRZ "Pure Red" - FRS "Ablaze"
White: BRZ "Crystal White Pearl" - FRS "Halo"
And so on. They have the same paint code, but different names for them. The only unique colors are Hot Lava and Oceanic for the FRS and World Rally Blue Pearl for the BRZ.
In other words they could call it pink polka dot for all it matters, if the paint code is the same it's the same damn paint!
tell me genius, where's your link showing that charlesite yellow is the same as sunrise yellow or yuzu for scion?
Old 06-28-2016, 06:59 AM   #91
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
HID is still superior in output. The diagrams says it's as good, but I'm doubting it. Now the LED fogs look just like the fogs I put on my car...
LED designed headlight is, from my experience, as bright as HID. My daily is a 2015 Corolla with OEM LED headlight. It look great, it's reallly bright and it don't generate heat on the housing like HID. The only minus, (on the Corolla) if the LED fail, the headlamp assembly must be replaced.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 06-28-2016, 08:22 AM   #92
Kendallkab
Drives: Black MT LMT BRZ
Soo if I were trading in a 13 at FRS soon should I get a series.blue since there's one near here for sale or wait for the 17. I'm leaning towards the series blue? Any opinions? If I don't get a series blue I'm waiting for the 17 regardless
Kendallkab is offline   Reply With Quote
Old 06-28-2016, 08:43 AM   #93
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
What does "R/C" mean in this context? I'm hoping this might be the fix we've all been waiting for.
Probably means running change. Somebody with a last batch MY16 should check under the hood.
Been using high output LEDs on my mountain bike and flashlights for a decade, and they generate ALOT of heat. I can imagine they must have massive headsinks on these LED car headlights somewhere at the back. If the heat doesn't dissipate then the light output would dim overtime.
Amazing how far LED technology has become, a palm size flashlight now can output like 1000 lumens.
krayzie is offline   Reply With Quote
Old 06-28-2016, 08:46 AM   #94
Da Brz
Drives: 2016 Subaru BRZ
I will sometime today if you guys want. My 16 BRZ has a build date of March 2016.
I'm looking for DENSO on it?
Da Brz is offline   Reply With Quote
Old 06-28-2016, 09:10 AM   #95
krayzie
Drive From Home
krayzie's Avatar
I've attached the picture.
The Following User Says Thank You to krayzie For This Useful Post:
Old 06-28-2016, 09:12 AM   #96
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Ah, no... the FR-S Release Series 1.0 colour is Yuzu yellow code C2Z.
What's a different yellow? The two links you provided clearly show that both the Subaru and Scion/Toyota yellow colours are the same paint code, C2Z.
You're mistake is in assuming that the new 2017 BRZ Special Edition in Charlesite yellow is a new for 2017 colour. Just like the guy with the Crosstrek Limited in the above link.
We don't know what the colour code is yet because it's not been released. BUT, most are predicting it'll be C2Z.
Old 06-28-2016, 10:32 AM   #97
Why is everybody trying to guess the yellow based upon pictures on a computer screen? I can look at the same pics on three different monitors and see three distinctly different shades of yellow. I would not even remotely want to guess if it is the same colour or not.
Eventually the code will be released and we will know beyond argument if it is the same or not but until then the debate is silly.
Elleteeh (06-28-2016)
Old 06-28-2016, 10:38 AM   #98
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Link is dead, anyone feel like re-uploading?
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
acetothermus (06-28-2016)
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread Rombinhood@OpenFlash Software Tuning 2594 08-01-2017 01:03 AM
Official: 2017 Acura MDX Teased, Will Debut In New York! Bye Bye Bird Beak? vh_supra26 Other Vehicles & General Automotive Discussions 4 03-23-2016 05:30 PM
2017 FRS Official Facelift Pics Zhangy Scion FR-S / Toyota 86 GT86 General Forum 2 03-17-2016 05:06 PM
Official New England random discussion thread! PRORICAN New England 503 07-24-2014 04:08 PM
Official FA20CLUB Turbo Kit FAQ Discussion FA20Club.com Forced Induction 67 01-09-2014 12:06 AM
