Old 06-27-2016, 09:07 PM   #71
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
To be honest if you looks away from the hype, The only thing that gives real performance is the 4.3 Final Drive. I think like 8/10 of us will install that....
Then brembos.
The Following 4 Users Say Thank You to chaoskaze For This Useful Post:
funwheeldrive (06-27-2016), Mr.Impreza (06-28-2016), nikitopo (06-29-2016), zc06_kisstherain (06-28-2016)
Old 06-27-2016, 09:33 PM   #72
Haha, not happening my friend. Several more months til official release info. Just gotta wait
Don't see how there is much more you could know that wasn't in that document. It is pretty comprehensive. Hell they even point out bolts that were changed.
Old 06-27-2016, 09:45 PM   #73
Elleteeh
Elleteeh's Avatar
Drives: '17 Subaru BRZ CWP Limited 6AT
Yeah, and not to mention the car will be out in September. At this point I think we all know what the car is and isn't going to be for the '17s.
Elleteeh is offline   Reply With Quote
Old 06-27-2016, 10:00 PM   #74
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Actually... There are several things they haven't mentioned. But again, they've listed pretty good amount of stuff, so good enough right?
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
funwheeldrive (06-27-2016), nikitopo (06-29-2016), Tcoat (06-28-2016)
Old 06-27-2016, 10:13 PM   #75
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
Maybe I didn't browse as indepth as I thought I did, but I could've sworn I heard about strengthening the rear half-shafts. Would that be one of the missing components?
OldSkoolToys is offline   Reply With Quote
Old 06-27-2016, 10:16 PM   #76
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
So, I know everyone was excited about the new Performance Package available on the 2017 - specifically the Brembo brakes. I tried to find information about the size of them in the PDF document, and couldn't find any direct information. Then I looked at the massive data spreadsheet at the end of the document. All the listed models for the US market had the same rotor diameter (294mm, which is ~11.5", which is the standard rotor size.)
On a whim, I looked at the Japanese models, and look what I found. I'm going to ASSUME that these are the Brembo rotors, considering that these models also come with the 17x7.5" wheels that you get with the Performance Package. If so, I'm seeing 326mm, which is ~12.8", which is ~1.25" larger than the standard size! A decent size increase!
This isn't an official confirmation, obviously, but it seems like a reasonable conclusion.
Stang70Fastback is offline   Reply With Quote
The Following 4 Users Say Thank You to Stang70Fastback For This Useful Post:
Hyper4mance2k (07-06-2016), Mr.Impreza (06-28-2016), raven1231 (06-27-2016), SuperDave (06-28-2016)
Old 06-27-2016, 11:18 PM   #77
ryoma
ryoma's Avatar
I am really curious if the Brembos are from the parts bin on other Subarus or if it was really developed for the BRZ specifically. more specifically, I wonder if there will be any change in brake bias with the performance package
Old 06-27-2016, 11:32 PM   #78
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Does full LED headlights mean that they no longer come with HID's?
I always thought that HID's were superior in functionality and looks/brightness compared to LED's. In the beginning when they were talking about LED I assumed they meant the drl and turn signals but I guess I'm wrong.
Oxyg3n is offline   Reply With Quote
Old 06-27-2016, 11:32 PM   #79
goldenfri
goldenfri's Avatar
Drives: 2017 BRZ Limited PP
Send a message via AIM to goldenfri
That matches up with the brake specs planet subaru already posted here:
http://www.planetsubaru.com/2017-subaru-brz.htm at the bottom of the "deep dive"
goldenfri is offline   Reply With Quote
Old 06-27-2016, 11:41 PM   #80
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
They have one design for BRZ like 2 years already under offical site.
Just Nobody in their right mind will pay 6k for a real set.
Old 06-28-2016, 12:43 AM   #81
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
I would give an A for effort and B- for the result. But I am sure it is definitely an improvement in every aspect from pre 2017 model.
Speed2th is offline   Reply With Quote
The Following User Says Thank You to Speed2th For This Useful Post:
chaoskaze (06-28-2016)
Old 06-28-2016, 12:51 AM   #82
Poodles
Originally Posted by SuperDave View Post
Can the series.yellow paint be swapped over to my 13 brz?
At least we know now from the document that this is a new yellow, not the sunrise yellow from the rs 1.0.
It's a "Charlesite yellow."
No, Subaru just names their colors differently than the FRS. It's likely the exact same paint code.
HID is still superior in output. The diagrams says it's as good, but I'm doubting it. Now the LED fogs look just like the fogs I put on my car...
It's really obvious that they've been looking at the modifications people have been doing to these cars in the aftermarket and just applying them stock. Interior trim, LED lighting, better tail lights...
Interesting note on the new high pressure fuel pump:
The fuel pump has been changed to a DENSO next-generation unit (R/C planned for 16MY).
What does "R/C" mean in this context? I'm hoping this might be the fix we've all been waiting for.
Also of note is that the new rear wing is aluminum.
Old 06-28-2016, 12:58 AM   #83
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
No. The rs 1 paint is called sunrise yellow.
SuperDave is offline   Reply With Quote
Old 06-28-2016, 01:05 AM   #84
Poodles
/facepalm
Paint CODE =/= paint NAME
Red: BRZ "Pure Red" - FRS "Ablaze"
White: BRZ "Crystal White Pearl" - FRS "Halo"
And so on. They have the same paint code, but different names for them. The only unique colors are Hot Lava and Oceanic for the FRS and World Rally Blue Pearl for the BRZ.
In other words they could call it pink polka dot for all it matters, if the paint code is the same it's the same damn paint!
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread Rombinhood@OpenFlash Software Tuning 2594 08-01-2017 01:03 AM
Official: 2017 Acura MDX Teased, Will Debut In New York! Bye Bye Bird Beak? vh_supra26 Other Vehicles & General Automotive Discussions 4 03-23-2016 05:30 PM
2017 FRS Official Facelift Pics Zhangy Scion FR-S / Toyota 86 GT86 General Forum 2 03-17-2016 05:06 PM
Official New England random discussion thread! PRORICAN New England 503 07-24-2014 04:08 PM
Official FA20CLUB Turbo Kit FAQ Discussion FA20Club.com Forced Induction 67 01-09-2014 12:06 AM
