Old 06-27-2016, 09:52 AM   #1
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Rust in clutch pedal area
I had squaky clutch sound for 2 weeks, so I took a look at underneath the dash for clutch pedal area but it's so rust inside there..
I never drive my car in winter and only has 38k km for 2013 Scion FR-S
what the hell is wrong with this.
bhbnuckle is offline   Reply With Quote
Old 06-27-2016, 09:54 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
haha I have a 2013 BRZ and a 2003 Accord DD.
Old 06-27-2016, 09:56 AM   #3
bhbnuckle
bhbnuckle's Avatar
LMAO
nice combination
Old 06-27-2016, 09:56 AM   #4
It is bare untreated steel.
Bare untreated steel rusts.
Will take decades before it is a problem.
Old 06-27-2016, 10:01 AM   #5
bhbnuckle
bhbnuckle's Avatar
i understand if I drove my car for 10 years. but only has been 3 years. shouldnt be doing this IMO
Old 06-27-2016, 10:04 AM   #6
Originally Posted by bhbnuckle View Post
i understand if I drove my car for 10 years. but its 2013 brand new. shouldnt be doing this IMO
All cars do it. Even brand new. Bare steel rusts. Always has and always will. It isn't financially feasible to paint or powder coat every single component underneath the car. It is only surface rust and is not hurting anything.
Old 06-27-2016, 10:17 AM   #7
Well this backfired on me!
Went and took a pic of mine to show what a 100K+, two winter car one would look like and SUPRISE!
Did you have something splash up there or something?
Old 06-27-2016, 10:41 AM   #8
bhbnuckle
bhbnuckle's Avatar
not at all sir.
bodyshop once cleaned interior tho including carpets.
Would that cause this issue?
or probably sitting my car for winter about 4 months every year will get the moistures developed in there?
I have no damn clue.
Hope it doesnt break in half while im driving .
Old 06-27-2016, 10:45 AM   #9
not at all sir.
AHHHH there is the culprit! Water and cleaning solution sprayed up while shampooing. You can almost see how it was splashed around once you know.
Like I said it is just surface rust and a complete non issue. Doubt it will even get any worse unless you have it cleaned again.
I really expected to see a mess when I looked at mine but I guess the ventilation is pretty good down there.
Old 06-27-2016, 10:54 AM   #10
bhbnuckle
bhbnuckle's Avatar
haha yeah should be fine.
Tcoat did u have annoying squeaky clutch sound too?
heard lots of 13/14 brz/frs having this issue.
Old 06-27-2016, 11:21 AM   #11
FX86
spray wd40 down there everywhere like a mad man
Old 06-27-2016, 11:38 AM   #12
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
WD40 will make it real easy to scrub off surface rust.
But be warned, WD40 is a "penetrating oil and water-displacing spray" its not actually meant as a lube. So your squeaking problem might fix itself for a little while but it'll come back.
Spray with WD40 to clean off the rust, and then find some actual lube and apply to moving parts.
Old 06-27-2016, 11:47 AM   #13
Nope not a sound.
Old 06-27-2016, 11:52 AM   #14
bhbnuckle
bhbnuckle's Avatar
the sqeuak itself is coming out of master cylinder or clutch fork.
not anywhere near inside cabin.
I just happened to look underneath and found out these rust lol.
Clutch Pedal rick s Engine, Exhaust, Transmission 51 09-20-2015 10:08 AM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
weird noise from clutch pedal area... mongiamc10 Issues | Warranty | Recalls / TSB 5 08-08-2014 06:04 PM
Anyone in Tacoma area willing to help with clutch pedal? EpidemicFRS Northwest 9 03-15-2014 04:02 PM
Anyone know how to stiffen the clutch pedal? 86main Engine, Exhaust, Transmission 3 03-01-2014 03:45 AM
