Old 08-21-2015, 09:43 AM   #1
rick s
rick s's Avatar
Drives: 2013 FR-S Ultramarine 6MT
Clutch Pedal
Well not a good start to the day!
Started off to work this morning, got the car into first gear. Went about 15ft and went to put the car in neutral to coast down the driveway and the clutch pedal goes to the floor and stays there
Driving yesterday there was no indication of any issue with the clutch so this morning really caught me by surprise.
Bad news was the problem with the pedal, good news was it had the decency to go in the driveway and not out on the road.
Any thoughts as to how big of a problem I have? The pedal needed to be moved off the floor by hand.
Any help would be greatly appreciated.
rick s is offline   Reply With Quote
Old 08-21-2015, 09:44 AM   #2
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Did you check your fluid?
Old 08-21-2015, 09:52 AM   #3
rick s
rick s's Avatar
I am at work now but will check when I get home. I am basically trying to get a feel for the severity of my problem. I am just hoping that the clutch itself is not what is causing the problem.
Thanks for your input
Old 08-21-2015, 10:03 AM   #4
Teseo
Drives: frs
Bleed out, maybe got air in the line
Old 08-21-2015, 10:53 AM   #5
Have you done any mods to the pedal or clutch?
Air, low fluid, etc should have given some sort of indication before complete failure unless it happened overnight while the car sat.
Old 08-21-2015, 10:55 AM   #6
YangerD
YangerD's Avatar
Drives: 2017 Toyota 86
Gotta do the simple checks; fluid, could be air, bleed the line etc.
YangerD is offline   Reply With Quote
Old 08-21-2015, 11:01 AM   #7
rick s
rick s's Avatar
no mods to the clutch or pedal, like I said operation seemed fine yesterday and this morning not
Old 08-21-2015, 11:04 AM   #8
rick s
rick s's Avatar
Absolutely! Just trying to get suggestions as to what it may or may not be! Not really fair to anyone replying but Just trying to get a feel for what may be going on!
Thanks.
Old 08-21-2015, 11:05 AM   #9
rick s
rick s's Avatar
On a side note are the master and slave cylinders accessible to check and/or replace?
Old 08-21-2015, 11:09 AM   #10
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Yes, Right on top of the transmission is the slave..Master is right on the firewall.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 08-21-2015, 11:36 AM   #11
rick s
rick s's Avatar
Thanks for the reply!
Old 08-21-2015, 11:54 AM   #12
For what it is worth page 134
http://www.ft86club.com/forums/attac...4&d=1339384129
Old 08-21-2015, 12:05 PM   #13
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
If the clutch pedal stays on the floor it sounds like your throw out bearing or master cylinder has failed.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 08-21-2015, 12:07 PM   #14
rick s
rick s's Avatar
Tcoat,
Thanks for the extra info! You can never have to much!
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
Clutch pedal peeping almost? Gillams Issues | Warranty | Recalls / TSB 3 07-22-2014 02:16 PM
Anyone know how to stiffen the clutch pedal? 86main Engine, Exhaust, Transmission 3 03-01-2014 03:45 AM
Clutch Pedal Noise Help!! ZackZ Scion FR-S / Toyota 86 GT86 General Forum 6 09-06-2013 05:35 PM
