Old 06-14-2016, 02:39 PM   #15
Norinradd
Drives: 2013 frs
Correct "......"
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 06-14-2016, 02:51 PM   #16
Norinradd
Drives: 2013 frs
Old 06-14-2016, 03:07 PM   #17
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
what code/cel comes up?
Old 06-14-2016, 03:24 PM   #18
Originally Posted by jasonojordan View Post
so you have an intake but no tune....
And a header.
86kahl (06-14-2016)
Old 06-14-2016, 04:14 PM   #19
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
Maybe stick to working on jeeps?
86kahl is offline   Reply With Quote
Old 06-14-2016, 04:23 PM   #20
86kahl
86kahl's Avatar
Can that scanner u got read fuel trims? What's your STFT right before you go into closed loop?
Old 06-14-2016, 04:53 PM   #21
Norinradd
Drives: 2013 frs
And a header..... Haha
Nope cant read fuel trims. Im assuming its just because of the intake. Being optimistic. Hoping i can get my hands on one sooner than two weeks. Then ill
Have some answers
Old 06-14-2016, 05:12 PM   #22
jasonojordan
Drives: 2013 satin white brz limited
or maybe you should stop driving it till you can get tuned...both a header and a intake are tuneable mods.
jasonojordan is offline   Reply With Quote
Old 06-14-2016, 05:19 PM   #23
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Does the car run/idle fine with the MAF disconnected?
- The Ancient BRZ Sacrament
by Zaku
Old 06-15-2016, 07:44 PM   #24
Norinradd
Drives: 2013 frs
Ok so update!! Got stock intake. Installed and unplugged battery overnight. Car ran great for an hour and a half. No stalls no sputters then BAM check
Engine light. My 3 other codes were wiped. The p0172 and p117 0/b. Which is what was causing my idle and stall.
Now im getting p0420 which i wasnt before!? Havent touched the header or o2s. Deleted the code. Wonder if it will come back? Any negative side effects of driving with p0420? What are my options in fixing it permanently
Other than putting stock header on. Which im not doing. Would a rear o2 spacer help!? I remember a previous member saying something of the sort
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties.
Just flashed OFT Stage 2 UEL Luftwaffel Software Tuning 14 11-30-2015 10:33 PM
Just flashed 2015 FRS with OFT Flat_4_Life Software Tuning 4 03-23-2015 10:22 PM
Anyone one flashed back and had a problem at the dealer? (chirp chirp chirp) OkieSnuffBox Software Tuning 16 11-18-2014 05:56 PM
Flashed ECU Djen Software Tuning 5 08-13-2013 10:00 AM
What car is flashed in the Mazda 3 commercial Yruyur Other Vehicles & General Automotive Discussions 10 03-29-2013 01:23 PM
