Old 06-14-2016, 09:17 AM   #1
Front 1ine
Drives: 2013 Scion FRS
Car won't start
I hope there is a quick fix and I'm just missing something. I'm a new owner so bear with me if this is a dumb question...
I get into my car and the dash light with the car and lock is flashing. I put my key in the ignition and the car responds with the normal beeping sound. I turn the key and the only light I see is the oil light. I let go of the key and the entire dash lights up like a Christmas tree and flashes sporatically.
But it won't start. the starter isn't even cranking. Nothinfg.
Any ideas?
Sent from my SGH-M919 using Tapatalk
Front 1ine is offline   Reply With Quote
Old 06-14-2016, 09:20 AM   #2
Front 1ine
The lights do dim when I turn the key.
Old 06-14-2016, 09:20 AM   #3
Boomerang
86
Boomerang's Avatar
if its a manual you need to depress the clutch pedal
Old 06-14-2016, 09:21 AM   #4
Front 1ine
Haha riiiiight.
Yes it's a manual. And yes...the clutch is depressed.
Old 06-14-2016, 09:23 AM   #5
Boomerang
86
Boomerang's Avatar
maybe battery terminals are loose/need cleaning or battery flat?
humfrz (06-14-2016)
Old 06-14-2016, 09:25 AM   #6
Front 1ine
That's my only guess. I'll try to jump the car and drive it to get the battery tested.
I just wasn't sure if there was something stupid like car not starting due to improper door locking procedure. Hmm...
Old 06-14-2016, 06:30 PM   #7
Like mentioned, my guess would be a weak battery.
http://www.aa1car.com/library/battery_runs_down.htm
Old 06-14-2016, 06:46 PM   #8
Front 1ine
I took the car battery to autozone. It read 11.5 V. They charged her up and it showed full voltage. It looks like I might have just a light on I guess.
Thanks for the help guys.
The Following User Says Thank You to Front 1ine For This Useful Post:
humfrz (06-14-2016)
Old 06-15-2016, 08:36 PM   #9
If your battery was down to 11.5V that means that
* maybe, your car is using more juice than the alternator is putting back
* maybe, the alternator is not working right
* maybe, you have a short that is draining the battery
* maybe, the battery is on it's way out
So, if it does it again ....... pick one......I'd start with a new battery......
Old 06-15-2016, 08:58 PM   #10
White64Goat
My original battery barely survived the winter and then the car would not start as yours did. Replaced the battery and it's been fine ever since. I jumped mine by pushing it down the street and putting it in second and letting out the clutch and it started, but I got the dreadful traction light and check engine light when I did. Thought I was screwed. Disconnected the battery for a while and it went away thank goodness. If you're a member of Costco, they have decent prices on Interstate batteries. They used to have their own brand of batteries and they were a Consumers Best Buy but for some reason they got rid of them.
Old 06-19-2016, 04:39 PM   #11
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Fill it with water. Don't forget.
Old 06-19-2016, 04:55 PM   #12
Or he left a light n overnight.
Old 06-19-2016, 05:22 PM   #13
......... no...no...that would be waaaaaaaay too simple .........
Old 06-21-2016, 10:10 AM   #14
Boomerang
86
Boomerang's Avatar
Front 1ine Quote:
Tcoat (06-21-2016)
BRZ Won't start jinyang1590 Issues | Warranty | Recalls / TSB 16 03-04-2016 04:28 PM
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 10:57 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
