Old 03-02-2016, 07:44 PM   #1
jinyang1590
Drives: 2015 BRZ WRB
BRZ Won't start
My car won't start, I have the Limited trim with the keyless start.
As soon as i open my door, I notice a few things:
1. The window does not slightly open and close with the door anymore, rather it is always in the slightly open state.
2. The car is constantly beeping until I close the door.
I know its not my battery because:
1. Tried jump
2. Everything in my car works, all lights, radio indicators...everything
I don't know if its the steering wheel lock, but I have tried the following:
1. Jiggling the steering wheel while pressing the start button
2. cranking and holding the steering wheel in one direction while pressing start (tried both directions)
I disconnected the battery and let it sit for a good hour and reconnected to try again, still no dice.
The car started and was running literally about 30 minutes before this happened. I think my immobilizer was tripped for some unknown reason. After trying to get the car to start for about 4 hours, gave up and called roadside assistance, it'll be towed to the nearest dealer.
Anyone know what the problem might be? This is driving me nuts.
jinyang1590 is offline   Reply With Quote
Old 03-02-2016, 09:18 PM   #2
humfrz
What did you do with the car for the 30 minutes between when it was last running and when you tried to re-start it .. ??
humfrz
Old 03-02-2016, 09:21 PM   #3
Bykov
Drives: 2014 Monogram FR-S Whiteout
Did you check the battery in your fob? They don't last very long according to Scion (though mine has been going twice as long as they have said it would already)
Bykov is offline   Reply With Quote
Old 03-02-2016, 09:28 PM   #4
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
humfrz
This also have you checked all your fuses ?
Old 03-02-2016, 11:06 PM   #5
jinyang1590
I haven't checked all fuses...but I have checked the ones that I thought were relevant, seemed fine. The key fob is about 6 months old, i doubt its the battery, plus I tried my spare fob and I can lock/unlock the door from the normal distance.
For the 30 minutes, i had taken apart the steering column cover to try and fix a rattle there, after I fixed that rattle (btw for anyone else having a rattle in the steering column, you need to tighten the nut located on the right side that tightens the lock mechanism for the steering wheel position) and put the cover back on, pushed the button to start the car and no go. The reason why I say that I'm not sure if its the steering lockout or not is because the steering lockout module is located right where that nut for the position lock is, I might have touched something the wrong way...I dunno. I did make sure all connections were seated properly multiple times.
Old 03-02-2016, 11:08 PM   #6
humfrz
Good idea!
Especially positions #21, #30, #45 in the main fuse box under the hood......
humfrz
Old 03-02-2016, 11:18 PM   #7
humfrz
Ahhh ...... yes, back to the scene of the crime ......
Has your car been towed off yet .. ??
If so, I suggest you call the dealership and explain what you were fiddling with just before the no start (before they really screw up your car ....... fixing something that ain't broke).
If you still have the car, you have a good idea where to start ...... fuses mentioned above and any relevant relays.
Let us know how you make out.
humfrz
Old 03-02-2016, 11:31 PM   #8
jinyang1590
humfrz
They are towing my car tomorrow morning, the dealer is literally a 2 minute drive from my house lol. But i'll check those three fuses in the morning before they haul my car away. I don't see how I could've messed up the steering lockout, the only thing I might've touched were some wires leading to the lockout module. Maybe something shorted out? I was tugging at the steering wheel kinda hard trying to get my hand around to get to that nut..maybe that had something to do with it...I dunno but I hope its an easy fix and I get to drive my car the same day, because I love my car dearly and everyday without it is like a mini anxiety attack for me.
Old 03-03-2016, 01:16 AM   #9
humfrz
Yep, sometimes it doesn't take much to mess up these modern day delicate cars.
I recall, back in the day, I was innocently changing the spark plugs in my old stove bolt 6 Chevrolet. Pretty straightforward job .... right .. ??
Well, I managed to twist off a sparkplug, such that the threads of the plug were still in the head. Sheeeeeeee-it!
So, I figured I'd have to take off the head, take it into the machine shop, have it drilled out and rethreaded for a larger plug.
When my grandfather saw me fixing on untwisting the head bolts, he ask me why I was doing that.
I showed him the remaining threads of the spark plug stuck in the head. He told me to go out to that coffee can, wired on the back of the old Oliver tractor and bring him that huge screwdriver, with the steel handle with wood inserts.
He calmly tapped (wedged) that screwdriver into the sparkplug hole and with a twist of his steel like grip, unscrewed the remaining part of the plug right out of the head.
He then told me to put the screwdriver back where I found it and ........ NOT to try to back out a plug (without squirting some kerosene around it), with a 1/2" drive socket ..... iffen it won't budge without a breaker bar.
Yep, back on our farm, we didn't have "easy-outs" or a set of taps or "PB Blaster".
I sure hope it's something simple with your car ........
humfrz
Old 03-03-2016, 09:40 AM   #10
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
with everything closed, turn the key to on, open the door while holding the unlock button for ten seconds. link shows page 83...it is the next pages 84-85
the alarm is triggered when the battery is disconnected if the car is locked..
https://www.joomag.com/magazine/suba...910946?page=83
thomasmryan is offline   Reply With Quote
Old 03-03-2016, 08:36 PM   #11
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Hey, no fair! Nobody reads the manual!
billwot is offline   Reply With Quote
Old 03-04-2016, 08:41 AM   #12
jinyang1590
does the alarm being triggered lead to a car being immobilized? I know about enabling and disabling the alarm, I don't know how this helps in my situation.
Old 03-04-2016, 11:09 AM   #13
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Not sure why he mentioned that either, I don't think its related to your issue. Even if tripping the alarm enabled the immobilizer, it'd be obvious cause the alarm would be going off too lol.
PandaSPUR is offline   Reply With Quote
Old 03-04-2016, 11:23 AM   #14
jinyang1590
Anyways, i just got off the phone with the dealer, it was just a blown fuse for the steering lockout. I must've shorted something out when i was tinkering around there. Its all good, funny because checking the steering lock fuse was the next fuse I was going to check, but the tow truck came before I could get around to checking it.
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Tad's CBS BRZ From The Start Tad_07 Member's Car Journals 8 10-12-2012 02:19 AM
