Old 06-10-2016, 01:55 PM   #29
wparsons
wparsons's Avatar
Originally Posted by 7thgear View Post
have you considered simply not running 245s and stick to 225s instead?
Running a narrower tire won't change the need for more camber... dropping to a 225 will still be chewing up the outer edge.
flickr
s0sl0w (06-12-2016)
Old 06-10-2016, 03:19 PM   #30
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by s0sl0w View Post
D) I'm not made of money. If I can get to the -2.5° I want for very little $$$ safely I would rather do that than waste money on top hats that's I'll be replacing next year with Racenseng's.
Thanks for the suggestions guys, @DocWalt has got me pointed in the right direction as well I believe. I just have to take the car off the road and get the struts off for a weekend.
Originally Posted by wparsons View Post
You don't need to take them out to slot them... mine were slotted while the car was on the alignment rack (just jacked up at the front). Just pull the front wheels, unbolt the knuckle and slot away with a die grinder.
I don't know how much time it took wparsons to cut a decent sized slot on the struts, but the lower bolts (SPC #81260) can be had for as little as under $30 from most vendors. This and transferring the factory lower bolt to the upper hole will get you the -2.5 your looking for. Though I'd like to see how much camber you can get just by slotting.
https://www.summitracing.com/parts/s...FVKDfgodD1wJTA
http://www.ebay.com/itm/Specialty-Pr...25.m3641.l6368 (for $21 plus these are galvanized too! The set I bought had the old black coating that is more prone to rusting)
Also, depending on the offset of the wheels you are using, you may need wheel spacers to clear the spring perch.
Intent > Content
Old 06-11-2016, 02:54 PM   #31
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
A friend of mine slotted his in an hour and has -3.3 on one side, -3.1 on the other (he needs to slot that one a little more). He's using a whiteline camber bolt as well. I took it out for one run and beat all my own times (in a borrowed FR-S lol) and all of his in one try. The camber WORKS and if you're looking for more camber it's basically free. Do it!
Edit: FWIW The bolt switching trick works well too, but won't get you as much. It might be good to try that first though: you might max out your tire clearance without even slotting the struts...
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 06-12-2016, 08:36 PM   #32
s0sl0w
Proud of Boxer
Do you have any photos of the slots?
s0sl0w is offline   Reply With Quote
Old 06-12-2016, 10:27 PM   #33
Keenercarguy
Mountain Runner
@s0sl0w I'm afraid not, and he's in the process of moving multiple states so I don't think he'll have the opportunity to snap photos anytime really soon. I'll shoot him a text though.
Old 06-13-2016, 10:16 AM   #34
wparsons
wparsons's Avatar
Total time for the alignment, including slotting the struts, was about 2.5 hours. A lot of that time was spent talking to Scott, if he was just working he probably could've done it all in about 1.5 hours.
flickr
solidONE (06-13-2016)
Old 06-13-2016, 05:35 PM   #35
solidONE
solidONE's Avatar
How much - camber gained from slotting by its self? I know that you can only go so far with the slot before the knuckle starts to make contact and bottom out on the main strut body/tube. Its probably a good idea to leave at least a 1~1.5mm gap between the knuckle and the body.
Intent > Content
Old 06-13-2016, 06:02 PM   #36
wparsons
wparsons's Avatar
I had about 1.5* from the bolts, we stopped at -2.2* because of tire/spring perch clearance. There's room to go much further if I had spacers or a different offset wheels.
flickr
18x9.5 stock height stock struts etherealfall Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-11-2017 05:44 AM
WTB: Stock wheels & rubber /// WTB: Stock Struts RickyRacer Canada Classifieds 13 05-20-2016 04:54 PM
Slotting struts for more camber sdm822 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-18-2013 11:05 AM
Slotting Struts ML Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-24-2013 03:08 PM
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 01:38 AM
