Old 05-23-2013, 01:38 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Slotting Struts
I have not seen a dedicated thread on slotting struts so I thought I would bring it up because I am thinking about doing this to the rear struts. NAOSIC says 1mm = -.8 degree of camber, and slotting the upper hole is ideal. I know you have to be careful about weakening the tower, and also the bolt slipping. Thoughts?
Old 05-23-2013, 01:42 PM   #2
ayau
Drives: Some rust bucket
Sure you need more camber at the back? Usually it's the front that rolls over.
Old 05-23-2013, 01:43 PM   #3
Racecomp Engineering
The rear of the car does not have struts. There is no upper hole to slot.
- andy
Old 05-23-2013, 01:48 PM   #4
ML
ML's Avatar
I have camber bolts in the front. I assumed since there are camber bolts for the rear that work the same way as the front that slotting would work the same in the rear as well.
Old 05-23-2013, 01:49 PM   #5
ML
ML's Avatar
- andy
Ok, quick look at a pic of the rear...yeah, really just need to get new arms.
Old 05-23-2013, 02:08 PM   #6
Yup. There's also a whiteline camber adjustment bushing for the upper arm that works well (and replaces a soft bushing with poly which is nice). The install is a pain though.
- Andy
Old 05-24-2013, 03:08 PM   #7
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
The "rear camber bolt" thing is just a camber bolt modified to work as the inboard rear LCA mounting bolt. There is a thread about it floating around here somewhere.
Not saying it works well or doesn't, just something I saw mentioned recently so that might be what you heard of.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
BRZ/FR-S Hood Struts - Any Interest? GrimmSpeed Cosmetic Modification (Interior/Exterior/Lighting) 943 07-27-2017 10:09 AM
WTB stock rear struts f0rge Canada Classifieds 3 04-11-2013 08:06 AM
Stock, OEM struts? ZN6 Nezz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 04-08-2013 06:17 AM
WTB: FR-S front struts edj Southwest 3 02-26-2013 04:00 PM
JDM BRZ Struts different than USDM BRZ Struts? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-30-2012 10:21 AM
