Old 06-07-2016, 06:37 PM   #1
s0sl0w
Proud of Boxer
Slotting stock struts
Has anyone slotted their stock struts? The hope is that next season a full coilover suspension, top hats and control arms will be on the car but for the remainder of this season my Hoosier A7's are only using about 2/3-3/4 of the 245 SW and I need more camber in the front very badly and very cheaply.
The car already has Whiteline camber bolts.
s0sl0w is offline   Reply With Quote
Old 06-07-2016, 09:42 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Very cheaply .. have you tried altering tire pressures to change grip?
Old 06-07-2016, 10:18 PM   #3
s0sl0w
Proud of Boxer
I'm already running the A7's at 28 PSI.
As measured with a tape, the rear is using the full 9 3/4" that's there, the fronts are using 6 1/4". That's alot of time and grip being lost.
Old 06-07-2016, 11:04 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Following very cheaply .. IIRC one can use camber bolts both in upper and lower mounting hole, to get slightly even more camber .. after that only options that cost more. Next in cheapness .. hmm, whiteline's camber/caster front mount?
Then there are more expensive options, camber plates and/or coilovers, that may already come with camplates and may have slotted holes. Some cheaper camplates (eg. Velox's $329/Beatrush $332) are not too expensive compared to mentioned whiteline's mount ($198) and ease a lot camber alignment, so i'd probably would go straight to them. Unless of course they do not fit in class rules.
Old 06-08-2016, 06:36 AM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
Whiteline doesn't sell those mounts anymore. They had a great many failures and pulled the product.
OP, slotting the stock struts shouldn't be an issue. I'd slot the top hole only, and if that isn't enough, pickup another set of camber bolts for the lower hole.
Old 06-08-2016, 09:57 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, i still saw those mounts in stock @ft86speedfactory, hence mention. I wonder though, what's there to fail, construction seems simple enough to be more robust then eg. generic alu camplates.
Old 06-08-2016, 11:19 AM   #7
Calum
That Guy
Even using the same bearing as the OEM mounts, but with better seals, they couldn't stop the bearings from going. I've seen bearings not make it to the end of the owners driveway. Hell, I've seen an owner put them in, torqued correctly, put the car down, turn the steering wheel from lock to lock, raise the car back up, and put the OEM ones back on. Didn't even need to move the car an inch and the bearings came out crunchy. WL either had the press fit too tight, or the position of the bearing allowing the additional camber and caster was causing the issue.
When WL was selling them one of the 'features' was that the mounts could be clocked to three different positions to give varying amounts of camber and caster. There was a few reports of people having success with the mounts, but I'm pretty sure everyone of those success stories came from people that weren't using them for max camber and caster.
Old 06-08-2016, 12:23 PM   #8
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I started to slot one of the upper holes on my factory strut. After spending some time and not seeing much progress and dulling some bits in the process, I decided to stick with the camber bolts. lol
It's totally doable with some time and elbow grease. How much camber are you looking to dial in? Its possible to get up to -3* using camber bolts alone.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Calum (06-09-2016)
Old 06-09-2016, 06:34 AM   #9
Calum
That Guy
I didn't know you could get that much! I never tried the upper and lower bolts. Nice.
Also, a 12mm camber bolt in the inner hole on the rear lower control arm can get you plus or minus .5 degrees.
Old 06-09-2016, 08:31 AM   #10
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by s0sl0w View Post
very cheaply.
Compare the cost of a proper solution to wasting $250+ each tires.
Old 06-09-2016, 09:20 AM   #11
Calum
That Guy
Getting the camber from bolts, slots, or plates isn't going to change the tire wear. Not getting the camber certainly will.
The Following User Says Thank You to Calum For This Useful Post:
wparsons (06-09-2016)
Old 06-09-2016, 09:38 AM   #12
OkieSnuffBox
Thank you for pointing out the obvious.
My point was if you're already dropping well north of $1k per set of Auto-X tires, go ahead and solve your problem the right way, vs the half-assed way.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
JazzleSAURUS (06-09-2016)
Old 06-09-2016, 10:17 AM   #13
wparsons
wparsons's Avatar
There's nothing half assed about slotting the struts... lots of good coilovers come pre-slotted on the upper hole. Adding camber at the knuckle is slightly better than at the upper mount because of the SAI.
To the OP, if you're running 245's you might not have any clearance at the spring perch to get extra camber from slotting the struts. I have my struts slotted and whiteline camber bolts, and maxed out at about -2.2* before there wasn't enough clearance between tire and spring perch. That's with 17x8 +45's and 225/45 AD08R's.
If you've got room, definitely slot the upper holes!
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
Calum (06-09-2016), Leonardo (06-09-2016), Ultramaroon (06-12-2016)
Old 06-09-2016, 10:21 AM   #14
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Put the 14mm bolt in the 16mm hole, and add camber bolts to the other hole. I got -3.8 degrees when I maxed out both sides before my alignment.
How much camber are you running now, and how much do you want to run?
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
18x9.5 stock height stock struts etherealfall Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-11-2017 05:44 AM
WTB: Stock wheels & rubber /// WTB: Stock Struts RickyRacer Canada Classifieds 13 05-20-2016 04:54 PM
Slotting struts for more camber sdm822 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-18-2013 11:05 AM
Slotting Struts ML Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-24-2013 03:08 PM
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 01:38 AM
