Old 06-07-2016, 05:32 AM   #1
Hugo
Drives: Toyota 86
5th gear grind
Hey guys,
I have searched relentlessly on this and it seems like people are getting their whole transmission replaced? Does anyone know if it could be the transmission mods that could be a problem too? I've only got the whiteline transmission shift kit and mtech shift springs installed and have had my OEM oil changed to martini full synthetic. Whats strange is that i didn't notice any grind prior to these mods and only put these on due to the side to side play that this gearbox has. Has anyone had any experience with it? I've got the 2015 GT86 btw. It only happens when im shifting really fast and driving aggressively also eg. heel toe and rev match 5th to 4th to overtake then getting back into 5th. All other gears are perfectly smooth, only getting into 5th from 4th.
Any help is greatly appreciated!
Hugo is offline   Reply With Quote
Old 06-07-2016, 05:54 AM   #2
raven1231
Remove parts and see if it still occurs. If not then you have your answer.
The Following 2 Users Say Thank You to raven1231 For This Useful Post:
Celica00 (06-07-2016), humfrz (06-07-2016)
Old 06-07-2016, 08:58 AM   #3
WNDSRFR
Drives: FR-S,GTI
What raven said. And if it still occurs, take it to the dealer and get it replaced.
Under warranty. For Free.
Old 06-07-2016, 12:00 PM   #4
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
Stop forcing gears, learn to shift smoothly during heel-toe. Sounds like your jamming it into place, probably have been for awhile but the new mounts are giving you more feedback. Id try shifting using just the base of your palm, very light pressure just allowing the shifter to go through the gates. And stop being so hard on the up shift, 1-4 are triple-synchro, 5-6 are single. It's not a dog box you can't just ram it into gear. (safely)👍🏽👍🏽
86kahl is offline   Reply With Quote
Old 06-07-2016, 01:54 PM   #5
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
You want to break that short throw hard shift habbit, grab the shifter at the base, you'll be forced to ease it in gear and not throwing it hard in gear
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
The Following User Says Thank You to RichardsFRS For This Useful Post:
86kahl (06-07-2016)
Old 06-07-2016, 04:15 PM   #6
Originally Posted by Hugo View Post
Hey guys,
WELCOME to posting to the forum, Hugo ........
Welp, IMHO you have "messed" with the transmission quite a bit ...... and now you are slamming it around ....... and wonder why it's not working too good ... ??
Like mentioned above, I'd suggest you take all that crap off of it and shift normal and see if that doesn't help .....
Old 06-07-2016, 05:20 PM   #7
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
i get the ocassional 4th to 5th grind
Old 06-08-2016, 09:33 AM   #8
Hugo
Drives: Toyota 86
So before i saw your replies, i called my mechanic and ask for his advice and went for a few test drives today and yesterday and tried many things before i was certain to take the parts out and make sure it wasn't me. eg making sure clutch was fully depressed, changing shifting style and I think you guys were right, it was how i was shifting.. funny how the mounts give me more feedback and i had to alter the style of shifting! No more grinds so far... touch wood and hope i don't jinx the tranny.. lol
Thanks for everyones input! Much appreciated!
The Following User Says Thank You to Hugo For This Useful Post:
86kahl (06-09-2016)
4th gear grind dallenj Engine, Exhaust, Transmission 15 06-03-2016 05:04 PM
5th and 6th gear grind... Basket Case Engine, Exhaust, Transmission 7 02-11-2015 09:53 PM
Grind Into 5th Gear Since885 Engine, Exhaust, Transmission 8 01-18-2015 06:47 PM
2nd gear grind (yup another one) SmartedPanda Issues | Warranty | Recalls / TSB 17 09-10-2014 05:02 PM
4th gear grind Moetivegt86 Issues | Warranty | Recalls / TSB 10 03-07-2014 12:50 PM
