Old 06-01-2016, 08:19 AM   #1
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
overcome stock maf limit with impreza MAF sensor
I'm using HKS v2 supercharger, and almost capped stock maf now. (4.9v 280g/s at 65ºF IAT )
in my country , no one can handle SD method for FRS, so I should find another easy way to use more boost.
We can use impreza (forester ) stock maf sensor to our car
without any modification.
part number is 22680AA380
same dimension, same harness
but much higher maf reading limit ( about 130%)
so we can use more boost without Speed density method.
Stock MAF sensor log datazap
http://www.datazap.me/u/yobiwan/hks-...3&zoom=647-833
Impreza MAF sensor log datazap
http://www.datazap.me/u/yobiwan/wrx-...3&zoom=368-688
both log are from same car, same boost.
you can see Maf voltage difference between them.
4.84v vs 4.44v on same boost , same RPM ,different IAT (77 ºFvs 91ºF)
it's first log with impreza maf scale, so afr is not on target.
but it's close enough to use.
cranking and closed loop driving were smooth too.
log after 1st open loop maf recalibration
http://www.datazap.me/u/yobiwan/wrx-...3&zoom=426-648
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
The Following 8 Users Say Thank You to Yobiwan For This Useful Post:
CSG Mike (06-03-2016), DAEMANO (06-01-2016), freerunner (06-01-2016), phrosty (06-01-2016), steve99 (06-02-2016), Trap63 (08-13-2018), Wayno (06-02-2016), ztan (06-03-2016)
Old 06-01-2016, 12:19 PM   #2
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hi,
If you need a tune for speed density I am sure we can accommodate. We now have over 1000 tunes across the world, with more than 500 of those running speed density.
So if you need any assistance, just let us know.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Yobiwan (06-01-2016)
Old 06-02-2016, 11:17 PM   #3
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Would this do any good for frs Brz without turbo charger? Any error code thrown?
turtlefeeder is offline   Reply With Quote
Old 06-03-2016, 03:28 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
It'll work if you change the map, if that's what you mean?
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-03-2016, 03:30 AM   #5
Yobiwan
Yobiwan's Avatar
no, it's for FI car. not for NA. you can use with NA car, but there is no benefit at all.
if you want to use WRX's MAF sensor, you should change MAF scale table in your ROM too.
I'll upload my maf scale ( after 1st open loop rescale) here.
The Following 4 Users Say Thank You to Yobiwan For This Useful Post:
1quickchic (11-19-2018), callisto (11-05-2025), turtlefeeder (06-03-2016), xkalelx (04-17-2017)
Old 06-03-2016, 07:23 PM   #6
ztan
Drives: Toyota 86
Nice work.
ztan is offline   Reply With Quote
The Following User Says Thank You to ztan For This Useful Post:
Yobiwan (06-03-2016)
Old 04-17-2017, 04:24 PM   #7
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Debating doing this for my 10.0:1 built FA. Not sure if its worth doing. I know it will be a hybrid tune as boost will be north of 22psi. Would the better resolution of the WRX MAF help the low speed driveability?
xkalelx is offline   Reply With Quote
Toyota GT [VIC]86 New stock Rims suit Subaru BRZ, Impreza jcage Australia Classifieds 1 11-29-2015 10:19 AM
Biggest challenge that you had to overcome in life? gt8613 Off-Topic Lounge [WARNING: NO POLITICS] 58 10-20-2014 12:18 PM
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 09:22 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
