#2395 | |
Drives: 13 BRZ WRB
#2396 |
Drives: 2013 Raven FR-S
This one actually came with the yellow bushings. Yeah, I greased them up really good when I installed the bar. I never hear the bushings squeak when I go over speed bumps or anything, so the lube still seems to be good.
#2397 |
Drives: Many
Maybe a dumb question, or covered elsewhere but...
Are you fast folks running re71s down to the bitter end (cords)? Are they equally fast until they aren't? Just trying to gauge when I should swap mine out. Just under 4/32 f/r after 90 runs of autox and 25-30 laps on a go-kart track. Packwood tours and pros are coming up and I'm hoping that I can make this set last til after then. Just wondering at what point they fall off a cliff -- 2/32? 1/32? Thanks for info! Last edited by e1_griego; 06-02-2016 at 09:14 AM. |
#2398 | |
The Stig's German cousin
| The Following User Says Thank You to renfield90 For This Useful Post: | e1_griego (06-02-2016) |
#2399 |
Drives: '22 BRZ
I'm curious about how daily driving miles affects them. I've got ~2k miles of street driving on mine, maybe a bit more. ~50 autocross runs and 4 hours of track time, down around 4/32 f/r. Still fast enough to nearly take local PAX win against fast drivers/cars. That may change by the time I hit 2/32
#2400 |
Drives: Many
kk, that's what I thought. Just wanted confirmation.
I've got probably around 1k miles on mine, just transit to/from events. Packwood is 200 miles away from me. Thank you! |
#2401 |
STX 188
They were good to me even at completely bald. Just harder to drive but the times come up the same.
| The Following 3 Users Say Thank You to tigermack For This Useful Post: |
#2403 |
Does anybody run Ace headers? Their 4-2-1 CS400 looks to work well for both auto-x and daily driving. I got a JDL UEL now, but I'm curious about Ace's overpipe being an extension of the header.
#2404 |
Doesn't that header eliminate both cats? If it's the long tube version I'm thinking of, it didn't look possible to run a cat within six inches of OEM. But my memory might be fuzzy.
#2405 | |
Drives: '22 BRZ
#2406 | |
Heat Cycles are what kill sticky tires. You can heat cycle them out well before the thread is gone. |
#2407 | |
| The Following User Says Thank You to ka-t_240 For This Useful Post: | e1_griego (06-14-2016) |
#2408 | |
Drives: '22 BRZ
I don't know how the heat cycles from DD use behave, are they half cycles because they never actually get HOT?FWIW I've got two autocrosses and a track day in the next week and a half and 2k miles of highway driving. I'll be putting on new tires before the end of July, I think. 4 months of use out of tires... Depressing
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
