Old 06-01-2016, 05:12 PM   #2395
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Originally Posted by smg1138 View Post
I forgot to mention the popping sounds only happen when I turn the wheel. I mostly notice it when pulling out of a parking spot or just turning the wheel when not moving. Put the car up on a lift last night to torque everything down and make sure the sway bar was centered. The noise went away for a while, but came back today after driving a bit. It's not a major deal, but pretty annoying since it's my daily driver.
Black bushings or Yellow? have you greased them?
2superblus is offline   Reply With Quote
Old 06-01-2016, 05:46 PM   #2396
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
This one actually came with the yellow bushings. Yeah, I greased them up really good when I installed the bar. I never hear the bushings squeak when I go over speed bumps or anything, so the lube still seems to be good.
smg1138 is offline   Reply With Quote
Old 06-02-2016, 01:19 AM   #2397
e1_griego
e1_griego's Avatar
Drives: Many
Maybe a dumb question, or covered elsewhere but...
Are you fast folks running re71s down to the bitter end (cords)? Are they equally fast until they aren't?
Just trying to gauge when I should swap mine out. Just under 4/32 f/r after 90 runs of autox and 25-30 laps on a go-kart track.
Packwood tours and pros are coming up and I'm hoping that I can make this set last til after then. Just wondering at what point they fall off a cliff -- 2/32? 1/32?
Thanks for info!
e1_griego is offline   Reply With Quote
Old 06-02-2016, 01:58 AM   #2398
renfield90
The Stig's German cousin
Just trying to gauge when I should swap mine out. Still at about 4/32 f/r after 90 runs of autox and 25-30 laps on a go-kart track.
Thanks for info!
Most people say they're fast down to the cords, unless you put a lot of daily drive miles on them.
The Following User Says Thank You to renfield90 For This Useful Post:
e1_griego (06-02-2016)
Old 06-02-2016, 08:41 AM   #2399
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'm curious about how daily driving miles affects them. I've got ~2k miles of street driving on mine, maybe a bit more. ~50 autocross runs and 4 hours of track time, down around 4/32 f/r. Still fast enough to nearly take local PAX win against fast drivers/cars. That may change by the time I hit 2/32
Old 06-02-2016, 09:14 AM   #2400
e1_griego
e1_griego's Avatar
Drives: Many
kk, that's what I thought. Just wanted confirmation.
I've got probably around 1k miles on mine, just transit to/from events. Packwood is 200 miles away from me.
Thank you!
Old 06-04-2016, 12:57 AM   #2401
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
They were good to me even at completely bald. Just harder to drive but the times come up the same.
tigermack is offline   Reply With Quote
The Following 3 Users Say Thank You to tigermack For This Useful Post:
DocWalt (06-05-2016), e1_griego (06-04-2016), justint5387 (06-04-2016)
Old 06-05-2016, 09:30 PM   #2402
Racecomp Engineering
Originally Posted by AFRichZC6 View Post
Does anyone here consider natural frequencies when choosing spring rates?
I'm considering joining STX next year.
Yes.
- Andrew
AFRichZC6 (06-15-2016)
Old 06-13-2016, 01:07 PM   #2403
toeout
Does anybody run Ace headers? Their 4-2-1 CS400 looks to work well for both auto-x and daily driving. I got a JDL UEL now, but I'm curious about Ace's overpipe being an extension of the header.
toeout is offline   Reply With Quote
Old 06-14-2016, 02:03 AM   #2404
renfield90
Doesn't that header eliminate both cats? If it's the long tube version I'm thinking of, it didn't look possible to run a cat within six inches of OEM. But my memory might be fuzzy.
Old 06-14-2016, 08:50 AM   #2405
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
It's fuzzy
Old 06-14-2016, 09:35 AM   #2406
ka-t_240
Heat Cycles are what kill sticky tires. You can heat cycle them out well before the thread is gone.
ka-t_240 is offline   Reply With Quote
Old 06-14-2016, 09:36 AM   #2407
ka-t_240
Thanks for info!
Mine were great until the end, they are probably all at 1/32nd give or take. Took them off cause I have a huge event coming this weekend(2 days of HPDE, 2 autox, and 1 high speed autox on the road course). needed some tread for rain.
The Following User Says Thank You to ka-t_240 For This Useful Post:
e1_griego (06-14-2016)
Old 06-14-2016, 10:41 AM   #2408
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'm well aware, that was my point. I don't know how the heat cycles from DD use behave, are they half cycles because they never actually get HOT?
FWIW I've got two autocrosses and a track day in the next week and a half and 2k miles of highway driving. I'll be putting on new tires before the end of July, I think. 4 months of use out of tires... Depressing
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
