#701 |
The Fail Boat
Drives: CWP S.B.
Old thread new post.. O.O Just got my TRD intake installed. I had drop in filter for 2 years.
Impression. It really smooth things out @ lower rpm, my car no longer choke for air when I'm coming to low rpm @ near stop & there is just a tad more power & get go everywhere + better top end. For an intake that subaru not gonna give you trouble unlike all other after market intake. I'd say it's prefect. Definitely a good upgrade.
| The Following 2 Users Say Thank You to chaoskaze For This Useful Post: | funwheeldrive (12-22-2016), mgarcia707 (04-04-2019) |
#702 | |
Drives: '15 BRZ RA
Why you didn't wait for the new intake? How about the sound tube? Is there a part included to close the hole? |
#703 |
Drives: GT-86
#705 |
Drives: TOYOTA
Dude is confused between intake manifold and (air) intake. The (air) intake should be the same in the MY17. It's the intake manifold that's been redesigned.
#706 |
Drives: '15 BRZ RA
Really? I thought that both intake manifold and air intake were re-designed.
#707 |
Drives: TOYOTA
Well, no one really knows for sure yet since Toyota hasn't released pictures, but everything I've read specifically states intake manifold. We'll see soon enough though.
| The Following User Says Thank You to Ro_Ja For This Useful Post: | nikitopo (05-30-2016) |
#708 |
Drives: 2015 Firestorm Scion FRS
oops my bad...thought I read air intake...which was kinda weird.
#709 | |
The Fail Boat
Drives: CWP S.B.
TRD Intake ! CAI ?!
Ya there is, they give you a cap to go on one side of the sound tube in engine bay. LOL I got mine from a friend for 220. So I think it's totally worth it, sound alone is a big improvement. I used to find my exhaust & intake pipe noise to be somewhat annoying @ times. Now it's just more enjoyable. As for the 2017 stuff we will see when they are out. Pretty sure ppl gonna put some of them on sale cheap, modding is just a joy with this car.
#710 |
Drives: '15 GT86 & '22 GR86
Thread bump!
Pretty much read this whole thread, whatever happened to more testing on this intake? It gets lots of positive reviews but there were concerns around MAF scaling and turbulence. If you run one of these with a modded snorkel does it royally mess up the MAF readings? |
#711 | |
My recommendation would be to not modify your snorkel in any way shape or form. Just leave it the way it is. Unless you have a dyno and you are actually tuning the car when you modify the snorkel you are basically just modifying it with magic pixie dust and rainbows as inspiration. If you haven't logged your MAF before and after to see how it changed as well as fueling accuracy and better yet map pressure / dyno readout then you are modifying it without science behind you to help you out.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following 2 Users Say Thank You to nelsmar For This Useful Post: | funwheeldrive (12-22-2016), wparsons (12-22-2016) |
#712 |
Nothing but changing maf diameter is going to alter the maf scale.
#713 | |
For the 86 specifically there are several intakes on the market with the exact same diameter MAF tube, and a completely different MAF scale. It's no coincidence why our intake's MAF scale is so close to stock, and it's not just because we're using the same diameter MAF tube. If that were the case, everyone else's intake would be perfect, wouldn't require any sort of MAF scaling and would be highly recommended. Chase Engineering |
#714 |
If that were the case, you'd need a different tune for every different weather condition, and that simple isn't the case.
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 01:43 AM |
| So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 09:06 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 02:31 PM |
