Old 05-27-2016, 01:12 PM   #701
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Old thread new post.. O.O Just got my TRD intake installed. I had drop in filter for 2 years.
Impression. It really smooth things out @ lower rpm, my car no longer choke for air when I'm coming to low rpm @ near stop & there is just a tad more power & get go everywhere + better top end. For an intake that subaru not gonna give you trouble unlike all other after market intake. I'd say it's prefect. Definitely a good upgrade.
Old 05-30-2016, 09:18 AM   #702
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Why you didn't wait for the new intake? How about the sound tube? Is there a part included to close the hole?
Old 05-30-2016, 10:32 AM   #703
acro
Drives: GT-86
What new intake?
Sent from my XT1575 using Tapatalk
acro is offline   Reply With Quote
Old 05-30-2016, 12:54 PM   #704
G-awesome
Drives: 2015 Firestorm Scion FRS
Originally Posted by acro View Post
What new intake?
I'm assuming the new metal intake on the 2017 brz?
G-awesome is offline   Reply With Quote
Old 05-30-2016, 01:33 PM   #705
Ro_Ja
Drives: TOYOTA
Dude is confused between intake manifold and (air) intake. The (air) intake should be the same in the MY17. It's the intake manifold that's been redesigned.
Ro_Ja is offline   Reply With Quote
Old 05-30-2016, 01:53 PM   #706
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Really? I thought that both intake manifold and air intake were re-designed.
Old 05-30-2016, 02:08 PM   #707
Ro_Ja
Drives: TOYOTA
Well, no one really knows for sure yet since Toyota hasn't released pictures, but everything I've read specifically states intake manifold. We'll see soon enough though.
Old 05-30-2016, 02:24 PM   #708
G-awesome
oops my bad...thought I read air intake...which was kinda weird.
Old 05-30-2016, 05:09 PM   #709
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
TRD Intake ! CAI ?!
Ya there is, they give you a cap to go on one side of the sound tube in engine bay. LOL
I got mine from a friend for 220. So I think it's totally worth it, sound alone is a big improvement. I used to find my exhaust & intake pipe noise to be somewhat annoying @ times. Now it's just more enjoyable.
As for the 2017 stuff we will see when they are out. Pretty sure ppl gonna put some of them on sale cheap, modding is just a joy with this car.
Old 12-20-2016, 01:06 PM   #710
Varelco
Drives: '15 GT86 & '22 GR86
Thread bump!
Pretty much read this whole thread, whatever happened to more testing on this intake? It gets lots of positive reviews but there were concerns around MAF scaling and turbulence. If you run one of these with a modded snorkel does it royally mess up the MAF readings?
Varelco is offline   Reply With Quote
Old 12-21-2016, 10:14 AM   #711
nelsmar
Originally Posted by Varelco View Post
Thread bump!
There are limitless possible modifications that could be made to the snorkel. All of which could slightly or drastically alter your MAF scale on all intakes. This also includes the stock one.
My recommendation would be to not modify your snorkel in any way shape or form. Just leave it the way it is. Unless you have a dyno and you are actually tuning the car when you modify the snorkel you are basically just modifying it with magic pixie dust and rainbows as inspiration.
If you haven't logged your MAF before and after to see how it changed as well as fueling accuracy and better yet map pressure / dyno readout then you are modifying it without science behind you to help you out.
My flickr - Canibeat
Local magazine scout
Old 12-21-2016, 10:36 AM   #712
Tokay444
Anti stance.
Tokay444's Avatar
Nothing but changing maf diameter is going to alter the maf scale.
Old 12-22-2016, 10:48 AM   #713
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
You'd be surprised. I have been testing different intakes for a very long time now, and there are many many many more factors to what influences the MAF scale than just the diameter.
For the 86 specifically there are several intakes on the market with the exact same diameter MAF tube, and a completely different MAF scale. It's no coincidence why our intake's MAF scale is so close to stock, and it's not just because we're using the same diameter MAF tube. If that were the case, everyone else's intake would be perfect, wouldn't require any sort of MAF scaling and would be highly recommended.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 12-22-2016, 11:42 AM   #714
Tokay444
Anti stance.
Tokay444's Avatar
If that were the case, you'd need a different tune for every different weather condition, and that simple isn't the case.
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
