Old 04-09-2016, 08:22 AM   #99
ChrisD
ChrisD's Avatar
Drives: GT86
Originally Posted by Tim Radley View Post
That's pretty low power for the spec like you say and that turbo looks nasty and laggy for the power. Power coming in at that rpm on most other 2.0 engines I build are all making 700+bhp
What compression and leakdown figures did you get? Just thinking maybe there is an issue there.
What is your oil consumption like now and is the catch can filling with oil?
Why is the boost so low, surely you could easily run 2 bar now?
I don't think this turbo will give anywhere near 2 bar of boost. Fensport said the most they got out of it was about 1.3 when they were using it on their car (race fuel, stock engine internals) and even on the stage 5 that they've just started testing they can only run 1.5 bar so far.
I've not seen dynos from other people using different turbos on a GT86 but I thought it was pretty normal for the power to start kicking in at about 4K RPM on a turbo GT86 (especially now that I'm on 10:1 CR pistons).
Like I said before, they did say they could push it further but I'd asked them to keep it as safe and reliable as possible because its going to be sitting bouncing off the limiter on drift days quite a lot.
Lets face it whatever the dyno results were, someone would be on here saying they could have tuned it better etc etc. I do think the dyno results are a bit misleading and that the tyres might have been slipping, but I don't care about dyno figures enough to go prove that just to satisfy people on a forum. At the end of the day I wanted it to be faster but still reliable, and that's what I've got. So I'm happy
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
The Following User Says Thank You to ChrisD For This Useful Post:
CxG (06-26-2016)
Old 04-10-2016, 05:48 AM   #100
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
Good on ya mate!! Enjoy!!
Nigelr32 is offline   Reply With Quote
Old 04-12-2016, 07:40 AM   #101
sam69
Drives: GT 86
Just wondering if you have any oil psi readings with the Reimax gears as I've seen people saying they give less pressure at lower revs and that they aren't worth putting in ?
Would like to hear your opinion on this ChrisD or anyone with the Reimax gears .
sam69 is offline   Reply With Quote
Old 04-12-2016, 06:58 PM   #102
DrawingWaves
DrawingWaves's Avatar
Drives: RS 1.0 #633
Noooooooooo the beautiful orange!!!
"Drive fast on empty streets with nothing in mind except falling in love and not getting arrested." - Hunter S. Thompson
DrawingWaves is offline   Reply With Quote
Old 04-12-2016, 07:32 PM   #103
Koj
Koj's Avatar
Drives: Toyota GT86
I m happy Chris to see you back to life XD
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more...
My Journal/Garage
Koj is offline   Reply With Quote
Old 05-09-2016, 06:22 PM   #104
ChrisD
ChrisD's Avatar
Drives: GT86
We just finished installing the Kaaz 1.5 way diff, in prep for a drift day later this week. I'll report back on whether or not I notice any difference compared to doing this same event last month on the stock diff. Video of the diff install here:
[ame="https://www.youtube.com/watch?v=XPANAX6DkJs"]GT86 Mods #14 - Kaaz 1.5 Way LSD - YouTube[/ame]
The Following 4 Users Say Thank You to ChrisD For This Useful Post:
CxG (06-26-2016), R2RO (10-14-2016), smudge (05-10-2016), TachyonBomb (05-29-2017)
Old 05-27-2016, 06:50 PM   #105
ChrisD
ChrisD's Avatar
Drives: GT86
Was never that happy with the wrap (peeling in several places) so earlier this week we peeled the wrap off and got the car re-sprayed in "stealth grey", which is the same colour the new Focus RS comes in. Pics below really happy with how it looks on the car, but I think I might need to change the colour of the wheels now...
The Following 11 Users Say Thank You to ChrisD For This Useful Post:
CxG (06-26-2016), djdnz (05-27-2016), D_Thissen (03-06-2017), Harvie1031 (05-27-2016), hmong337 (05-28-2016), JonAvalon (05-27-2016), Kris86 (01-27-2017), Lonewolf (05-28-2016), R2RO (10-14-2016), spitfire481 (05-29-2016), weederr33 (05-27-2016)
Old 05-27-2016, 11:35 PM   #106
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Wow the car looks great in that color!
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
ChrisD (05-28-2016)
Old 05-28-2016, 01:32 AM   #107
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Sorry didn't go through the entire thread but how much whp does this car produce? What is the complete setup?
hmong337 is offline   Reply With Quote
Old 05-28-2016, 05:41 AM   #108
Nigelr32
That colour looks great Chris!!
Did you end up with any spare diff shims you might like to sell on?
The Following User Says Thank You to Nigelr32 For This Useful Post:
ChrisD (05-28-2016)
Old 05-28-2016, 06:56 AM   #109
ChrisD
ChrisD's Avatar
Drives: GT86
It's only been on one dyno run and we suspect the wheels might have been slipping towards the top end but it got 335 bhp there. Setup is 10:1 compression ratio and 1.2 bar of boost with the AVO stage 4 turbo
Old 05-28-2016, 06:59 AM   #110
ChrisD
ChrisD's Avatar
Drives: GT86
We managed to re use the stock diff shims in the end. The only reason we thought they weren't going to fit is because we hadn't quite got the bearings all the way on. Once we'd got them seated properly the stock shims measured up fine.
On a completely unrelated note, was it you that made your own wide arch kit or am I thinking of someone else?
Old 05-28-2016, 07:48 AM   #111
Nigelr32
Yep, that was me..
I only have only made moulds for the fenders and bumper spats, eight pieces. I am also able to make a one piece front wing complete so you don't have to cut the wing at all.
There is a big difference with mine and other copies in the UK.. mine actually fit.
The Following 2 Users Say Thank You to Nigelr32 For This Useful Post:
ChrisD (05-29-2016), DustinS (10-14-2016)
Old 05-29-2016, 02:43 PM   #112
ChrisD
ChrisD's Avatar
Drives: GT86
Yeah I saw someone else mention that they got a set from you and it fit perfectly. If I was going for it I'd only want the front and rear fenders. Not sure if I'm going to do it yet, depends if I get a steering angle kit for drifting or not. I'll drop you a PM if I do though and hopefully I can get the fenders from you if you're still making them.
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit P&L Motorsports Forced Induction 234 09-24-2015 04:45 PM
For sale: Avo Stage 1 turbo kit h4nh Engine, Exhaust, Bolt-Ons 4 09-26-2014 02:36 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit P&L Motorsports Engine, Exhaust, Bolt-Ons 56 09-22-2012 03:28 PM
