IG: large2
10 months old - battery dead this am. Auto off headlights?
Wanted to keep the title short. When I turn the ignition off in my 15 - the headlights stay on for quite a while before shutting off. Is there a work around for this? Or do I just use the blinker stalk to shut them off? Not an issue either way. I just wouldn't expect the battery to die since it came from the factory this way, although I am not even certain that was the culprit. Trunk lid was shut and glove box was as well and I can't think of anything else. Any input is appreciated.
#2 |
Drives: 2015 Scion FR-S
Press the lock button twice to turn them off. Are you the same Large from TacomaWorld?
#3 |
IG: large2
That I am .. thanks! I knew about the double tap but I wouldn't think Scion designed the headlights to kill the battery if I don't double tap it. I might just keep the blinker stalk on off instead of auto.
#4 |
The dealer can reprogram them to turn off sooner. There are also a few apps that can be used to set the parameters but the only one I know the name of is Carista.
#5 |
*****istrator
Drives: 2013 Scion FR-S 10-Series M/T
You can set it in TechStream to turn off immediately after turning the engine off.
SC10N FR-S #435 of 2500
#6 | |
IG: large2
#7 |
Old Mechanic
Drives: 2013 Limited BRZ
Sometimes the plates inside the batteries warp. Shortening the life considerably. Could have a premature bad battery.
Sent from my SAMSUNG-SM-G930A using Tapatalk |
#8 |
Huge E85 fan!
Drives: 2016 Scion FRS
Is the battery drained or is it dead? If the lights were left on and the battery is just drained, charge it up and you're back in business. What is the battery doing? Are there any lights in the car, does the engine click when you turn it over or is the car just 100% dead (no noise or lights at all), or are the interior lights brown?
#9 |
Don't forget the factory battery is pretty crappy.
#10 |
Check the electrolyte level in the battery. Be ready to add distilled water if needed.
#11 |
I didn't like the delay, first thing i did with the techstream was to turn off the delay. Lights turn off when my door opens.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| Dead battery | technoid | BRZ First-Gen (2012+) — General Topics | 17 | 03-17-2016 04:17 PM |
| Car WON'T START dead battery? | AnthonyArcaro | Issues | Warranty | Recalls / TSB | 17 | 01-19-2016 12:00 AM |
| Dead battery | Mikeez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 33 | 08-07-2015 09:58 AM |
| Dead battery. | AlanKent | BRZ First-Gen (2012+) — General Topics | 50 | 03-31-2015 01:36 AM |
| Dead battery!?! | Hoahao | Issues | Warranty | Recalls / TSB | 5 | 02-23-2015 04:06 PM |
