| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Dead battery.
So it has been cold here in Colorado and I think it caused my battery to die. I have another vehicle that I drive if there is snow on the ground, but today was nice so I decided to take the BRZ out. It was only about a week ago that I last drove it. Is this typical? Should I be shopping for an Optima battery to replace the factory one? Plus, my dash no longer says what gear I am in (manual trans). How do I get it to do that again? Thanks in advance!
A.K.A. Starlord
Drives: 2015 Series.Blue
Your battery shouldn't be dead after a week no matter how cold it is. The car also isn't old enough for it to just need to be replaced. Though I suppose it could be a defective battery. I'd be more inclined to think you accidentally left a light on.
Yet another reason I'm going all-LEDs soon :P |
That's the thing. I couldn't find a light that was left on. As long as it is not a known problem I won't worry about it unless it happens again. Anyone have ideas on how to restore the gear indicator?
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Mine does the same. the battery is weak.
Drives: '13 BRZ Limited, '95 BMW M3
Mine sat outside in co also during the last snow and fired up just fine after a week of sitting
Drives: Toyota Highlander; Subaru BRZ (SWP)
Edit: Desktop version: [ame="https://www.youtube.com/watch?v=EL50fh9-_9A"]2013 BRZ FRS: How To Set Shift Light and More HD - YouTube[/ame] Last edited by carma143; 11-22-2014 at 11:54 AM. |
SLO NO MO
Stock battery is hit or miss. Several of us have seen it lose charge quickly.
I've got an Optima yellow top now. Sent from my Nexus 5 using Tapatalk |
#9 | |
Drives: 2013 BRZ Sport-tech WRB
The car will shut off any lights accidentally left on after 20 mins. |
#10 |
Drives: 2013 BRZ Limited
Really, why do you need an Internet post to help you determine if your battery is bad. Go to an auto parts store and get it tested.
#11 |
I love my series blue brz
Drives: 2010 335d
did you arm your car with alarm? but if you have warranty, you should always go back to dealer to claim it.
#12 |
Drives: Subaru BRZ Series.Blue
When the battery is disconnected, the Gear Indicator and Rev light/indicator will go back to default, which is off. Fortunately your radio stations will stay the same. But for your situation its a dead battery rather than a disconnect. There might be a parasitic draw somewhere like a light left on somewhere that will drain your battery. Anything above 50mA (0.050A) is too high of a draw with car off.
#13 |
It was to see if it was a common problem and whether or not I should replace it with an after market one. Not all batteries are built the same. Some factory batteries are down right cheap.
#14 |
SLO NO MO
| Dead battery; starts up in limp mode | kilrb | Issues | Warranty | Recalls / TSB | 15 | 01-04-2018 02:54 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
| Is there any know that how to open the truck when the battery is dead?????? | wilson0326 | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-06-2013 09:24 PM |
| Dead Battery BUT Honk Horn and it Turns on Car | ScionFR-S | Issues | Warranty | Recalls / TSB | 9 | 06-11-2013 02:47 PM |
| Ignorance and a dead battery | Red John | Issues | Warranty | Recalls / TSB | 9 | 03-02-2013 01:29 PM |
