Old 05-27-2016, 09:57 AM   #1
Large
IG: large2
10 months old - battery dead this am. Auto off headlights?
Wanted to keep the title short. When I turn the ignition off in my 15 - the headlights stay on for quite a while before shutting off. Is there a work around for this? Or do I just use the blinker stalk to shut them off? Not an issue either way. I just wouldn't expect the battery to die since it came from the factory this way, although I am not even certain that was the culprit. Trunk lid was shut and glove box was as well and I can't think of anything else. Any input is appreciated.
Large is offline   Reply With Quote
Old 05-27-2016, 10:23 AM   #2
armyoffoo
Drives: 2015 Scion FR-S
Press the lock button twice to turn them off. Are you the same Large from TacomaWorld?
armyoffoo is offline   Reply With Quote
The Following 2 Users Say Thank You to armyoffoo For This Useful Post:
FRSBRZGT86FAN (05-27-2016), Large (05-27-2016)
Old 05-27-2016, 10:41 AM   #3
Large
IG: large2
That I am .. thanks! I knew about the double tap but I wouldn't think Scion designed the headlights to kill the battery if I don't double tap it. I might just keep the blinker stalk on off instead of auto.
Old 05-27-2016, 11:38 AM   #4
The dealer can reprogram them to turn off sooner. There are also a few apps that can be used to set the parameters but the only one I know the name of is Carista.
Large (05-27-2016)
Old 05-27-2016, 11:48 AM   #5
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
You can set it in TechStream to turn off immediately after turning the engine off.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
The Following User Says Thank You to azian_advanced For This Useful Post:
Large (05-27-2016)
Old 05-27-2016, 11:53 AM   #6
Large
IG: large2
Thanks for the replies! I have a service appointment soon and I will ask them to see what they can do.
Old 05-27-2016, 11:55 AM   #7
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
Sometimes the plates inside the batteries warp. Shortening the life considerably. Could have a premature bad battery.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Respect BRZ is offline   Reply With Quote
Old 05-28-2016, 06:42 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Is the battery drained or is it dead? If the lights were left on and the battery is just drained, charge it up and you're back in business. What is the battery doing? Are there any lights in the car, does the engine click when you turn it over or is the car just 100% dead (no noise or lights at all), or are the interior lights brown?
guybo is offline   Reply With Quote
Old 05-28-2016, 09:17 AM   #9
FirestormFRS
Don't forget the factory battery is pretty crappy.
FirestormFRS is offline   Reply With Quote
Old 05-28-2016, 01:29 PM   #10
Check the electrolyte level in the battery. Be ready to add distilled water if needed.
Old 05-28-2016, 10:12 PM   #11
stevesnj
stevesnj's Avatar
I didn't like the delay, first thing i did with the techstream was to turn off the delay. Lights turn off when my door opens.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
FRSBRZGT86FAN (05-28-2016)
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 04:17 PM
Car WON'T START dead battery? AnthonyArcaro Issues | Warranty | Recalls / TSB 17 01-19-2016 12:00 AM
Dead battery Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-07-2015 09:58 AM
Dead battery. AlanKent BRZ First-Gen (2012+) — General Topics 50 03-31-2015 01:36 AM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 04:06 PM
