Old 05-24-2016, 04:30 PM   #547
DarkSunrise
DarkSunrise's Avatar
Originally Posted by renfield90 View Post
Highly recommend you run a higher octane at the track than what your tune was set up for, if at all possible. Extra insurance.
Thanks yeah I usually do top off with 100 octane at the track for peace of mind. Final mix ends up being about 94-95 octane.
2022 BRZ Build
2013 FR-S Build
Old 05-24-2016, 08:31 PM   #548
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by DarkSunrise View Post
Tried flashing the new OFH tune on my car:
- JDL catless UEL / OP
- Berk catted FP
- Perrin CBE
Drove 30 minutes on the highway to build some LTFTs, then logged a few pulls.
First impressions are it feels stronger than the old tune I was using (v. 2.074). It appears it's not running as rich as before and there's more ignition timing at the top of the RPM range (previously tapered to 25* at redline, now holds nearly 30*). I do see slightly more FLKC and KC on the log, but nothing alarming so undecided whether I'm going to use this at the track or not.
http://datazap.me/u/darksunrise/ofh-...zoom=4411-5121
http://datazap.me/u/darksunrise/ofh-...1&zoom=229-313
Going to do a few more data logs in the coming weeks and see how LTFT's and FLKC/KC looks.
Why was your IAT so high? were you just idling and letting it heat soak right before the pull? Also if you bring up you oil temps before logging, it would be more indicative of what will happen under track duty. But it looks pretty good considering the IAT were over 110.
Intent > Content
Old 05-24-2016, 09:03 PM   #549
DarkSunrise
I noticed my IAT's have been high ever since I installed an oil cooler. On the highway my IAT's sit about 20-25 F above ambient. On track it's more like 15-20 F above. I think the oil lines running so close to the intake box seem to be heating the air up.
My oil temps for those pulls were around 200-205 F. My peak track oil temps hit 245 F. I'd love to log pulls with those kind of oil temps, but not sure how I'd get them that high on the street.
2022 BRZ Build
2013 FR-S Build
Old 05-24-2016, 09:30 PM   #550
solidONE
solidONE's Avatar
One way to bring it up is do back to back to back 3rd gear pulls. Like 10x in a row. If people see you doing it they'll probably think you're crazy. I do it all the time after making adjustments to the calibration and collecting data to convert to dyno using virtual dyno. We have an industrial/warehouse area by where I live that's perfect for that. Not sure if you'll hit peak oil temps (maybe after 15~20 pulls), but it will get up there.
Intent > Content
Old 05-24-2016, 09:42 PM   #551
DarkSunrise
Hmm... there used to be an industrial area I went to for bedding track pads at night. But the last time I went, I pulled into the complex and my heart nearly jumped out of my chest when my headlights lit up two cop cars just sitting there waiting in the dark. Was a long awkward moment as I made a three-point turn in my loud rumbling FR-S with track-pads squealing and slowly slinked away lol.
I need to find another place to do some repeated pulls and brake bedding...
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
CSG Mike (05-25-2016)
Old 05-24-2016, 10:01 PM   #552
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I too noticed higher IATs with oil cooler, I assume mostly cause it's down there dumping heat into the air before it gets sucked into the snorkel.
Also, my oil temps peaked at 218F on track a couple weeks ago... With a busted ass oil cooler missing some peak flow.
Old 05-24-2016, 10:24 PM   #553
DarkSunrise
Yeah my peak oil temps from Sunday were close to that, around 222 F. Loved how cold the weather was that day! Logs showed minimal knock.
2022 BRZ Build
2013 FR-S Build
DocWalt (05-24-2016)
Old 05-24-2016, 11:25 PM   #554
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
With the way the intake snorkel is located and how the oil cooler works that seems normal, the hot "dirty" air from the oil cooler radiator core is being dumped and naturally pulled upward into the intake.
Old 05-25-2016, 07:33 AM   #555
DarkSunrise
Yeah that's a good point too. In hindsight if JR's oil/radiator cooler kit had been out earlier, I probably would have gone that route even if it meant slightly higher oil temps.
2022 BRZ Build
2013 FR-S Build
Old 05-25-2016, 08:53 AM   #556
OkieSnuffBox
Drives: '23 BRZ Limited
Put in third gear and run 6k rpms on the highway until the oil temp gets to where you want it, or close to.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
DarkSunrise (05-25-2016)
Old 05-25-2016, 10:02 AM   #557
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
So after the luster of a shiny new toy has worn off a bit. How are people liking these tunes? I'm tempted to give it a whirl finally but don't want to waste my time if it's not noticeably faster
Old 05-25-2016, 10:54 AM   #558
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
the butt dyno feels a good bump from 2k to 4k RPM and 6k to redline
tdotBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to tdotBRZ For This Useful Post:
DocWalt (05-25-2016), D_Thissen (05-25-2016)
Old 05-25-2016, 11:23 AM   #559
D_Thissen
D_Thissen's Avatar
Has anyone tried this tune with a Borla UEL?
Old 05-25-2016, 11:33 AM   #560
tdotBRZ
tdotBRZ's Avatar
be the first, tune the beast and then datalog so we can both pull some timings
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
