| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Scion FR-S
How accurate is FRSProject?
So it seems like http://www.frsproject.com/ is no longer up and running. This is the source I used to determine what adapters I need to get my wheel's flush.
I am currently running +48 offset wheel's with custom made 28mm adapter's. This would bring my offset to +20, yet when I went to mock fit it, it poked like CRAZY. When I ran what +20 offset wheel's would look like on projectfrs, it projected that it would be flush with the body. I feel like an idiot not double checking this before purchasing custom adapter's. I am also completely stock suspension. Here are the mock fit: ![]() So were the fitment on frsproject completely wrong? Last edited by lupindub; 05-13-2016 at 09:16 PM. |
#2 |
Drives: 2005 Toyota Camry
"flush" depends on what alignment, what make/size of tires, and what point on the car you are measuring the "flush" part from.
#3 | |
Drives: Scion FR-S
I haven't messed with the alignment on the car since I got it. Regardless of tire size (even if I went 215 on my 17x8), would this not be considered a poke? Going 215 might not make the tires bulge out but it seems like the wheel is poking out quite a bit.
#4 |
Drives: 2013 White-Out FRS
Picture doesn't work, but you gotta take into account the wheel width AND tire size and a meaty tire size makes a more poke-y look.
I believe, with my set-up which is 17x9 +35, it's flush in the rear at -1 camber (I'm at -2 now) and and a bit poked in front. Take into account how many mm you get each inch you add to the wheel. So a 17x10 would poke a lot more even with offset being higher like 17x10 +48.
I live my life one quarter-pounder at a time.
#5 | |
Drives: Scion FR-S
By the way would you mind explaining the logic behind how the 17x8 would poke more then the 17x7 even though they have the same offset? Wouldn't the extra 1 inch width just go inside the wheel well? Edit: Pic should be working now. |
#6 | |
The offset does push the wheel out more, but they wouldn't make super wide wheels width wise if it goes into the wheel wells. At that point, almost no car would be able to use them lol. Imagine a 18x10.5 +30 going into the wheel well. That would just stab into it. What wheel size are you looking for?
| The Following User Says Thank You to HachiRo For This Useful Post: | lupindub (05-14-2016) |
#7 | |
Drives: 2014 Ultramarine FR-S
| The Following User Says Thank You to NLSP For This Useful Post: | lupindub (05-14-2016) |
#8 | |
Drives: Scion FR-S
#9 |
17x8, +48 is pretty much perfect (functional) fitment on its own. No need for that spacer.
#10 |
Drives: Scion FR-S
#11 |
Drives: Scion FR-S
So at this point do you guys think I should just sell these wheel's and buy something that fits better? I don't mind if it's not hella flush but is this simply too much poke? I'd really like to keep these wheel's if possible and the adapter's are unfortunately non-refundable.
#12 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
I'm also a bit puzzled that nobody asked you if you're lowered or not, and also that the wheel, once you fit tires on it and actually put the car on them will sink in compared to having them just mounted without the car putting the weight on the suspension. Also tire choice makes a big difference. Doing the math I come up with a slight poke, which you could deal with using camber bolts and springs, or better, coilovers wher you can set the camber. Example. Your 8x17 +20 is about what a 9x17 +32 would be. The 9" wide wheels in the range of +35 to +40 are about flush (depending on tires and suspension and bla, but more or less) So we are actually talking about 3-5mm poke. Some example pictures: This is 8.75x18 +35 (so about 8x17+25 in your case), add another 5mm to this and you are about what it looks on your car - on stock suspension http://www.ft86club.com/forums/showp...1&postcount=75 Now the same setup 1" lowered, with almost factory camber http://www.ft86club.com/forums/showp...&postcount=172 This setup is on 245 tries, so you could louse 20mm tire wide when you go with a 225 tire. The wheel itself would still poke a bit, but the tire would be more or less inside the fender. (you can see on the picture that the tire pokes more than the wheel) I'm not telling you your setup is ideal, but its also not that horribly off and non fixable. Either get 15/20mm adapter plates if you can, or get coilovers/camber bolts, either way you could fix your issue. I would check with a garage/tuner you trust in your area, and get a proper offer on what you could do to make it work. Again, its not ideal, but it is not poking that much as it is when you make a mock up without putting the car weight on the wheels. Hope this helped a bit, feel free to shoot me a message if you need more math done
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
| The Following User Says Thank You to Killerbee For This Useful Post: | lupindub (05-14-2016) |
#13 |
LMGTFY
Drives: 13 FRS, 91 Miata
Are you taking into account what the wheel looks like with actual weight on the suspension.
It may be closer to flush if the car wasn't jacked up in the air. Don't know how you can do that though without a tire. |
#14 | |
Drives: Scion FR-S
I will be running 215/45 tires so that should reduce the tire poke ever so slightly. Also would the wheel actually sink in a bit once I put it on the ground even if I am on stock suspension? I had heard it will only sink in if you are lowered or you adjust your camber. (not sure how true this is.) |
| How accurate is Torque program | Riftur | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 02-02-2016 07:55 AM |
| Torque App - 100% Accurate Fuel Remaining | B-R-Z | Engine, Exhaust, Transmission | 0 | 08-29-2014 04:16 PM |
| Disp Temperature not accurate | marinjim | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 08-22-2012 08:16 AM |
| How accurate? | Maps316 | BRZ First-Gen (2012+) — General Topics | 18 | 08-02-2012 08:28 AM |
| Accurate Engine Impressions | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 1 | 12-16-2009 12:05 PM |
