Old 05-12-2016, 10:33 PM   #1
Votlon
Votlon's Avatar
Drives: Scion FRS || Ducati 899
E85 changes exhaust tone?
I got some tomei uel headers and i've been running e90-80 from a local gas station for the last 5k miles. Never had a problem and love e85
I decided I should put some 91 with some detergents in the tank for the hope of cleaning a little, so I ran the tank down to e45 with 91 from shell and was just driving around a little and the car seriously sounds different!
I normally pull from any gear around 3k rpm to get around cars but at e45 I need to pull from 3.8k-ish to hit the powerband. My guess is since the headers are uel and the powerband is different, the air is colliding at different intervals in the headers making a really different exhaust note.
Just a theory but I'm gonna get a good mic and test it to find out! :p
Votlon is offline   Reply With Quote
Old 05-13-2016, 06:16 AM   #2
Is the car tuned for E85 and you are running other mixes?
Old 05-13-2016, 06:27 AM   #3
Votlon
Votlon's Avatar
Car is tuned for flex fuel, which could use different cam timings between 91-e85, id have to check
But i mainly run e85 only
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 05-13-2016, 07:22 AM   #4
jasonojordan
Drives: 2013 satin white brz limited
Hopefully you have a flex fuel module that pulls timing for different fuels...
jasonojordan is offline   Reply With Quote
Old 05-13-2016, 07:55 AM   #5
Votlon
Votlon's Avatar
Yeah I run Dtuning's module (:
The Following User Says Thank You to Votlon For This Useful Post:
jasonojordan (05-13-2016)
Old 05-13-2016, 08:15 AM   #6
steve99
Drives: FT86
As the flex fuel sensor detects lower content of ethanol it signals the ecu. The ecu then adjusts the fueling and ignition timing for the new ethanol content. The difference in ignition timing from petrol to E85 can be up to 10 degrees or so. This is likely to change the exhaist note as well as the power and torque charasteristics of the engine. some tunes may also adjust the intake and exhaiust cam timing as well and boost levels on turbos
Guff (05-13-2016)
Old 05-13-2016, 08:17 AM   #7
Votlon
Votlon's Avatar
As the flex fuel sensor detects lower content of ethanol it signals the ecu. The ecu the adjusts the fueling and ignition timing for the new ethanol content. The difference in ignition timing from petrol to E85 can be up to 10 degrees or so. This is likely to change the exhaist note as well as the power and torque charasteristics of the engine
Yeah thats that i was thinking too,
But the question of the day is will it be louder! :p we will find out tomorrow or today I guess I dont sleep enough!
Old 05-13-2016, 08:35 AM   #8
May not be "louder" but will have a different tone and resonance which could be perceived as loud. The actual volume probably doesn't change much.
Guff (05-13-2016)
Old 05-13-2016, 09:57 AM   #9
babydriver
Hit the road and I'm gone
babydriver's Avatar
What a cool discussion! Thanks guys.
Slip, slidin' away.
Old 05-13-2016, 10:21 AM   #10
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Personally, while on E85 both I and my GF had noticed the exhaust tone become more refined yet even maybe a little quieter. I think the tune is why this happens.
Instagram: trevor.parque
Old 05-13-2016, 11:34 PM   #11
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
LOL. My girlfriends car is opposite. At least with the supercharger.
clayrush is offline   Reply With Quote
Anyone else hate the stock 2-tone wheels?? FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 58 07-08-2015 03:19 PM
do HFC really change res. exhaust tone that much? BlackyRose Engine, Exhaust, Transmission 0 08-24-2014 11:57 AM
Perrin 2.5 resonated exhaust tone change? merino_frs Engine, Exhaust, Transmission 4 01-29-2014 06:48 AM
Revive Your Exhaust Tone with Our Debut FT86Club Exhaust Clearance Sale! FRSport.com Engine, Exhaust, Bolt-Ons 0 09-06-2013 02:08 PM
AE86/FR-S Exhaust Tone neutral Scion FR-S / Toyota 86 GT86 General Forum 7 08-23-2012 08:55 AM
