-   -   E85 changes exhaust tone? (https://www.ft86club.com/forums/showthread.php?t=105700)
Votlon 05-12-2016 11:33 PM
I got some tomei uel headers and i've been running e90-80 from a local gas station for the last 5k miles. Never had a problem and love e85 :)
I decided I should put some 91 with some detergents in the tank for the hope of cleaning a little, so I ran the tank down to e45 with 91 from shell and was just driving around a little and the car seriously sounds different!
I normally pull from any gear around 3k rpm to get around cars but at e45 I need to pull from 3.8k-ish to hit the powerband. My guess is since the headers are uel and the powerband is different, the air is colliding at different intervals in the headers making a really different exhaust note.
Just a theory but I'm gonna get a good mic and test it to find out! :p
Tcoat 05-13-2016 07:16 AM
Is the car tuned for E85 and you are running other mixes?
Votlon 05-13-2016 07:27 AM
Car is tuned for flex fuel, which could use different cam timings between 91-e85, id have to check
But i mainly run e85 only :)
Sent from my SAMSUNG-SM-G870A using Tapatalk
jasonojordan 05-13-2016 08:22 AM
Hopefully you have a flex fuel module that pulls timing for different fuels...
Votlon 05-13-2016 08:55 AM
Yeah I run Dtuning's module (:
steve99 05-13-2016 09:15 AM
As the flex fuel sensor detects lower content of ethanol it signals the ecu. The ecu then adjusts the fueling and ignition timing for the new ethanol content. The difference in ignition timing from petrol to E85 can be up to 10 degrees or so. This is likely to change the exhaist note as well as the power and torque charasteristics of the engine. some tunes may also adjust the intake and exhaiust cam timing as well and boost levels on turbos
Votlon 05-13-2016 09:17 AM
Originally Posted by steve99 (Post 2651399)
As the flex fuel sensor detects lower content of ethanol it signals the ecu. The ecu the adjusts the fueling and ignition timing for the new ethanol content. The difference in ignition timing from petrol to E85 can be up to 10 degrees or so. This is likely to change the exhaist note as well as the power and torque charasteristics of the engine
Yeah thats that i was thinking too,
But the question of the day is will it be louder! :p we will find out tomorrow or today I guess I dont sleep enough!
Tcoat 05-13-2016 09:35 AM
May not be "louder" but will have a different tone and resonance which could be perceived as loud. The actual volume probably doesn't change much.
babydriver 05-13-2016 10:57 AM
What a cool discussion! Thanks guys.
MisterSheep 05-13-2016 11:21 AM
Personally, while on E85 both I and my GF had noticed the exhaust tone become more refined yet even maybe a little quieter. I think the tune is why this happens.
clayrush 05-14-2016 12:34 AM
LOL. My girlfriends car is opposite. At least with the supercharger.
