Old 05-11-2016, 10:26 PM   #1
zooki
Drives: waiting on a 2021...
Swapping back to Pentosin.
Changing out the transmission fluid in my 13 FRS. I had used Pentosin in it, but last fluid change I went with Motul 300 in both the trams & rear end. I change the fluid every 25K, and have decided I prefer the Pentosin in the gearbox better. I did run Redline in the rearend previously, but like the Motul 300 for that application better. It seemed to "tighten up" the feel of the Torsen, although I don't know how it could. But, the gearbox just felt smoother with Pentosin in it, probably because it's a little lighter weight fluid.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 05-12-2016, 08:11 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm running a mix ~50:50 of Redline 80 and 85. This also feels MUCH better than Motul 300.
Old 05-12-2016, 08:46 PM   #3
ryoma
ryoma's Avatar
I am using Motul in my trans as well as diff and it feels great. though, this is the only fluid that I have used apart from the OEM fluid so I have no idea what other fluids are like.
Old 05-12-2016, 11:23 PM   #4
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Is Anybody out there still on the stock fluid without problems?
Am I the only one?
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 05-13-2016, 05:36 AM   #5
Tbird232ci
Drives: 2013 FRS
Am I the only one?
54K miles on the stock fluid still. Not a single problem. Getting changed this coming week though.
Tbird232ci is offline   Reply With Quote
The Following User Says Thank You to Tbird232ci For This Useful Post:
Spartarus (05-13-2016)
Old 05-13-2016, 03:52 PM   #6
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
I'm on stock fluids for about 17,000km. I want to change mine, purely for something to do. Will probably change to some form of Aussie brand though.. not sure. And maybe do supercharger fluid at the same time.
COO86L is offline   Reply With Quote
Old 05-13-2016, 04:00 PM   #7
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Am I the only one?
Well, stock-ish...at least it's Toyota-supplied. The stealership drained the original fill when they did my clutch fork warranty work @15,000 miles, but refilled it with Toyota 75W LV (after first filling it with Subie GL5 gear lube...). I recently bought a liter of the 75W LV to do a partial refresh, as I'm at ~30K miles now. $50/liter...ouch.
Old 05-14-2016, 06:07 AM   #8
Calum
That Guy
Am I the only one?
I changed the fluid after 10,000 kms as break in maintenance. I first went to Motul 300 as everyone and their dog, from the south, says it's amazing. It sucks big fat hairy balls in cold weather though, so I switched about a week later. The guys at my local race shop and myself looked at the OEM fluid specs and decided on the mix. I didn't have any significant problems with the OEM fluid though. Second was a little notchy, but it was still livable.
Old 05-14-2016, 12:19 PM   #9
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Am I the only one?
Not exactly your target demographic but we've got all Motul products in the race car, knock on wood we haven't had any issues yet with the trans and the diff issues were mainly from trying to run a fresh new diff in a 13 hour race with no cooling.
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
DriftinFRS (05-14-2016)
Is this the right Pentosin mtf-2 Raven604 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-09-2014 09:58 PM
Swapping back to summers mezdup NY / NJ / CT / PA 8 03-29-2013 11:43 PM
Issues Swapping Back/Forth from 5spd MT & 6spd MT? endos2000 BRZ First-Gen (2012+) — General Topics 29 02-17-2013 02:56 PM
Looking for Pentosin MTF-2 in Ontario? wtout86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-26-2012 07:07 PM
