Old 05-12-2016, 07:07 PM   #29
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Probably a heat shield vibrating..
mine has done it on a few of them.
Get under car, swing a hammer around a few times until you break things.
noise gone.
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 05-12-2016, 07:24 PM   #30
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
For my car, this was the shifter lockout. Remove it and put some teflon tape on the bolt. Put it back together, no more rattle.
SpectreRT is offline   Reply With Quote
Old 05-29-2016, 05:55 PM   #31
zmz0305
Drives: subaru brz
Originally Posted by FRSteve91 View Post
Sorry to bump an old post, but I've got some important info on this.
Bought my FRS with 17k miles on it back in December. I noticed this metallic-type buzzing right away where the torque dip starts to end (4-4.5 rpm). My car was recently tuned about a month ago by a friend, and the buzzing is still there.
When I was in for service last week (oil change), I explain it to them and had them take a look. They want me to bring my car in tomorrow so they can remove the TRD exhaust and install a stock one, to see if that makes it go away (not my idea obviously, thats what the manager/tech/whoever recommended they do)
I'll update here tomorrow when they tell me what's going on.
Also, should I worried about them spotting the tune somehow? I'm fairly new cars, mechanically.
any update on your exhaust?
zmz0305 is offline   Reply With Quote
Old 05-29-2016, 06:15 PM   #32
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
my shifter makes noise now.
Fix?........err............. no idea.......=/
Old 06-01-2016, 08:20 PM   #33
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Stock knob? The little ring around the bottom of mine would rattle. Drove me insane, so I got a giant hunk of steel shift knob.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 06-01-2016, 08:30 PM   #34
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I have the sti knob where the entire piece is metal with leather wrapped on the side. I can make the noise go away if i pinch the shifter linkage under the shift boot.
Old 06-21-2016, 03:19 AM   #35
2point0
2point0's Avatar
Didn't some people talk about their reverse lockout rattling? That might be with aftermarket shifters, I don't recall. But it could be a thing.
Old 11-14-2017, 04:34 PM   #36
Wolf359
Wolf359's Avatar
Drives: 2017 Toyota 860 Halo white
Mine does it at 4500 rpm, but it sounds more like lifter rattle to me than a vibration. Still pretty new so I'll keep trying to figure it out.
Sent from my Pixel XL using Tapatalk
Wolf359 is offline   Reply With Quote
Old 11-21-2017, 01:19 PM   #37
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
17 BRZ Buzz in cab drivers side
I'm getting a buzz with my 17 Yellow Series. Naturally the tech couldn't reproduce it, but I'm looking at a few possibilities.
Symptoms: aprox 2 second buzz in cab in the area of the speaker/window controls/under dash. Only happens while driving, not RPM related, at anywhere from 15 to 80mph.
Possible causes:
-Cabling under dash
-Cabling around speaker
-Door step trim
-Window/lock controller
-Air bezzle
-Left dash access pannel
If anyone fixed this, give me a heads up. If I find it or fix it I'll post
snowtaipan is offline   Reply With Quote
Old 11-21-2017, 02:51 PM   #38
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
@zmz0305 - My mechanic, Shiv from OpenFlash, and Delicious all assured me that metallic buzz in the 4-4.5k range is normal. I could hear it slightly on the stock tune on my '13 FR-S, and it was louder with an OFT or EcuTek tune. I can hear it on my '17 BRZ, too.
TofuJoe is offline   Reply With Quote
Installed Amp & Speakers, getting constant buzz Gir Electronics | Audio | NAV | Infotainment 8 11-16-2012 03:28 AM
Continuous BUZZ/HUM from HPFP in ACC mode. stevo_12v AUSTRALIA 2 10-22-2012 06:46 AM
Metallic based tint DSOmegaX BRZ First-Gen (2012+) — General Topics 11 08-26-2012 03:15 PM
DBA 4000 T3 Slotted Rotors for BRZ/FR-S at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-07-2012 01:41 AM
Canadian Pricing Prediction: Scion cheaper by $4000 minimum. pastuch Scion FR-S / Toyota 86 GT86 General Forum 6 11-03-2011 09:44 PM
