Old 05-08-2016, 03:15 AM   #29
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Originally Posted by seito23 View Post
I would check my intake thoroughly. Check the filter for any damage or obstructions. Make sure all the connections are tight.
I hear it, sounds like a faint white noise whistle.
Very unlikely,but worth checking maybe a small exhaust leak. Check at the gasket seals
To be sure, my professional opinion, buy an intake and exhaust. You know, to be thorogh and all.
hmm agree with the first part, should check all component for leaks and break that has to do with flowing air currents of sort. than replace or repair the parts that you spot broken or damaged so you won't waste money replacing things that are not necessary.
turtlefeeder is offline   Reply With Quote
The Following User Says Thank You to turtlefeeder For This Useful Post:
zmz0305 (05-08-2016)
Old 05-08-2016, 10:42 AM   #30
zmz0305
Drives: subaru brz
Yeah, that's my car! Thanks!
I'll be leaving right after my last final, so unfortunately I probably won't be able to meet up. However, I live in Chicago, so I'll be coming down occasionally next semester to see what's what, so we can definitely meet then!
Cool! I thought you are going back to Texas because the location in your profile LOL.
Good luck in the finals!
zmz0305 is offline   Reply With Quote
The Following User Says Thank You to zmz0305 For This Useful Post:
Guff (05-08-2016)
Old 05-08-2016, 10:45 AM   #31
zmz0305
Drives: subaru brz
Originally Posted by 86kahl View Post
I get the same noise, it's like an electrical whirl/whistle while coasting on the freeway and lightly on the throttle?
Yes exactly! Now it happens while idle too, though not all the time.
Do you have any idea what is that sound?
Old 05-08-2016, 10:54 AM   #32
zmz0305
Drives: subaru brz
Thanks for the info! I am planning to get an intake this summer.
I went through a lot of brands and had a hard time making a choice. Do you have suggestions? Ideally I would love to have most HP gain. Which brand is the best?
Old 05-08-2016, 04:00 PM   #33
seito23
Drives: Corn Juice junkie
To be clear, that was a joke, I feel bad having to explain that. Most people have to explain their purchases or get "buy in" from a significant other. "Hey hun, my car is acting up and I need to buy a few parts to fix it." Excuse granted!
@the OP in regards to intakes that produce HP gains. Unless the intake is feeding some forced induction there is little to no gains to be had.
seito23 is offline   Reply With Quote
The Following User Says Thank You to seito23 For This Useful Post:
Tcoat (05-09-2016)
Old 05-08-2016, 04:32 PM   #34
zmz0305
Drives: subaru brz
Yeah I know there could only be like 2-5 hp most, but still there are ones that are good and ones that are better, right?
Old 05-08-2016, 05:42 PM   #35
seito23
I would purchase a new rubber intake hose like the Mishimoto. I just personally never liked that metered air was being used to pump sound into the cabin. especially on closed loop systems, if you notice, a lot of stock twins have very spotty tailpipes from the rich condition. Remove all the extra nonsense.
Old 05-08-2016, 09:46 PM   #36
zmz0305
Drives: subaru brz
what do you mean "have very spotty tailpipes from the rich condition"?
Old 05-08-2016, 09:49 PM   #37
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
Like when cars get black soot on the bumper cuz the unburned fuel from the rich AFR
86kahl is offline   Reply With Quote
Old 05-08-2016, 10:14 PM   #38
Oh, yes ........ simply put a K&N drop in filter into your car's stock air box......
Now, wasn't that easy ......
Old 05-09-2016, 10:10 AM   #39
zmz0305
Drives: subaru brz
I mean, I don't quite understand the meaning of "rich" in here. Could you explain it a bit please? And how it could cause unburned fuel?
Sorry english is not my first language and I am kind of car noob here.
Old 05-09-2016, 10:13 AM   #40
zmz0305
Drives: subaru brz
Well, wouldn't have much fun if it is too easy right?
Old 05-09-2016, 11:41 AM   #41
I'll butt in here .....
By "rich" they mean that the car is burning an AFR (air fuel ratio) that is heavy on the "fuel" part of the ratio.
In this case, a black, sooty deposit may show up on the tail pipe outlet.
Back-in-the-day, one could almost "measure" the AFR by looking at the inside of the tail pipe ....... if it was black, the engine was running rich, it was whitish, the engine was running "lean" ...... so, a light, smoke color deposit was "good".
The AFR could be changed by "adjusting" the carburetor(s) or the engine timing.
Today, I have no idea how the ECU (Engine Control Unit) alters the AFR.
However, someone in the know, will have to explain that to you ......
seito23 (05-09-2016)
Old 05-09-2016, 11:55 AM   #42
Well yes ....... but you still have "fun" with a oiled drop in (if you are old).
find and purchase the correct filter
find the air box
figure out how to open it up
unpackage the new filter
anguish over if it has enough oil or too much oil
now, which way does it go in ....... frontwards/backwards .... upside down/right side up
why won't the air box cover close ....
worry that it has too much oil and it will gum up the air flow sensor thing
not enough oil and it will let in dirt and the engine will grind itself up
take it for a drive
YES! AT least 3 more HP and 2 ft lbs of torque, measures on your butt dyno .........
All for $40.00 and 15 minutes of labor ..........
Time for a nap!
noise, whistle
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 10:21 PM
whistle noise in 6th? Lydin Engine, Exhaust, Transmission 43 10-28-2016 02:45 PM
Engine whistle between 2-2.5K RPM ShackontheTarget Issues | Warranty | Recalls / TSB 2 05-15-2015 02:25 PM
Turbo Whistle v. Blower Whine SupraLove Forced Induction 34 11-21-2012 08:56 PM
