Old 04-28-2016, 02:04 PM   #15
c8Face
c8Face's Avatar
Drives: 2016 BRZ
Originally Posted by Freude am Fahren View Post
I have a feeling the 1-6 indicator uses speed/rpm to figure out which gear it's in, which is why it only reads with the clutch out (as opposed to reverse, which must use the reverse switch). So maybe a final drive change? Or maybe differently sized front/rear tire diameter. Don't know why it would only effect 3rd, maybe just how ranges work out in the computer. Just spit-balling here.
Very good point abut the final drive ratio. I did notice the rpms seemed high when driving in the city (although I only picked up the car last night). I'll have to monitor my rpms at various speeds/gears and compare to videos online. As mentioned above, I bought the car with 2500km on it, and it had a bunch of track ready parts (AP Racing nrakes, Ohlins coilovers, sticky tires, etc). It wouldn't surprise me if there was a final drive ratio change.
c8Face is offline   Reply With Quote
Old 04-28-2016, 09:40 PM   #16
c8Face
c8Face's Avatar
Drives: 2016 BRZ
Based on the speed/rpms while driving home today, it looks like the previous owner did perform a final drive ratio change. In 3rd gear at 3000rpm, my speed was around 49km/h. From what I have read in other threads, the stock ratio in 3rd gear at 3000rpm is 54km/h.
I knew there were mods done when I bought the car, but this was a bit of a surprise!
Thanks for the input everyone.
The Following User Says Thank You to c8Face For This Useful Post:
Tcoat (04-29-2016)
Old 04-28-2016, 10:27 PM   #17
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
yup, more or less the final drive has been changed if there is a difference between your gear indicator and your actual gears.. what i did, i asked my tuner to adjust it when they tuned my car so now it shows the correct gears in the indicator
one thing also to find out if the final drive has been changed is to check the top speed for each gear.. i believe first gear maxes out at 60kph and with a 4.556 final drive, i think its around 49kph if im not mistaken
2013 Toyota 86
Sterling Silver Metallic
IG: @pcuerpo.images
pcuerpo is offline   Reply With Quote
The Following User Says Thank You to pcuerpo For This Useful Post:
c8Face (04-30-2016)
Old 04-28-2016, 10:46 PM   #18
c8Face
c8Face's Avatar
Drives: 2016 BRZ
Good to know that it can be adjusted. I'll probably just leave it as is and keep the G-off setting. It's a cool feature, but something I can live without. I was more concerned that I had a problem with the car. The final drive change explanation totally makes sense. Thanks!
Old 04-29-2016, 10:12 PM   #19
Wonder if there are more surprise mods? Have you checked if it is tuned in anyway?
Old 04-29-2016, 10:13 PM   #20
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
http://www.spencerfabricationcompany...grade-program/
Aozora.BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to Aozora.BRZ For This Useful Post:
drewbot (04-29-2016), Tcoat (04-29-2016)
Old 04-29-2016, 10:28 PM   #21
c8Face
c8Face's Avatar
Drives: 2016 BRZ
I have acually asked the dealership where I bought the car to contact the original owner and ask what mods were done and at what shop he worked with. Hopefully they can get in touch with him so I can get a bit of history on the car.
In any case, I plan to take the car to an indy shop for an oil change at 5000kms. They know Subies very well and maybe they can provide some insight.
To be honest, I was originally looking for a non-modded BRZ but when I came across this one, it was too tempting to resist. The prior owner must have been a true enthusiast with the type of parts installed.
So far I have identified:
1. AP Racing big brake kit font/back
2. Ohlins coilovers
3. Final drive ratio change (I suspect it is from MFactory due to the increase in noise)
4. Eibach anti roll kit
5. 18 inch rims (still trying to figure out the model)
6. ....
Tcoat (04-29-2016)
Old 04-29-2016, 10:46 PM   #22
2. Ohlins coilovers
6. ....
I would be surprised if there are not some more hidden mods with that list.
It is a long shot but have you looked through the Vancouver regional sub or the build threads on here? You may stumble across a thread on it.
Old 04-29-2016, 11:21 PM   #23
c8Face
c8Face's Avatar
Drives: 2016 BRZ
I have looked, but unfortunately have not found anything online. The previous owner only had the car for 6 months, and apparently traded it in for the new MX-5 - he must have read the recent Motor Trend comparison
One more goodie I forgot to mention were the Weathertec mats in the front/back/trunk.
Tcoat (04-29-2016)
Old 04-29-2016, 11:56 PM   #24
Ohhhhhh now it is a game! When on the computer and not my phone I am going on a quest. Probably futile but I will enjoy the challenge and the search.
Old 05-14-2016, 02:35 AM   #25
c8Face
c8Face's Avatar
Drives: 2016 BRZ
@Tcoat, I posted this in another thread, but I did find out a bit of history on my car!
https://www.instagram.com/p/BB6TI9iE...performanceone
https://www.instagram.com/p/BA0wBk8E...performanceone
Tcoat (05-14-2016)
Old 05-14-2016, 02:42 AM   #26
Nice work!
Old 07-07-2017, 12:39 AM   #27
Blue Bird
Blue Bird's Avatar
Drives: '14 BRZ
I have the same issue. Ever since I did warranty work on the tranny, my gear indicator shows a random gear whenever I shift to neutral. My backup camera stopped working too. Wack.
Blue Bird is offline   Reply With Quote
Old 07-07-2017, 01:00 AM   #28
There are two switches in the transmission. One tells the ECU when it's in neutral. The other is for reverse. I wonder if they forgot to connect them.
The connectors sit right on top of the bell housing. Do your backup lights work?
Blue Bird (07-07-2017)
BRZ HUD Gear Indicator Missing? norcalpb BRZ First-Gen (2012+) — General Topics 25 06-15-2015 06:55 AM
FT86 GT manual gear indicator KamalT Engine, Exhaust, Transmission 3 10-04-2012 09:43 PM
MT gear indicator WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 19 07-02-2012 10:20 PM
MT Gear Indicator Issue civicdrivr Scion FR-S / Toyota 86 GT86 General Forum 28 05-21-2012 11:40 PM
Gear indicator Slick CANADA 18 05-20-2012 10:14 AM
