Old 04-23-2016, 02:41 AM   #15
Originally Posted by DaJo View Post
I don't believe they replaced my switches... =/
All I saw on the warranty invoice was the replacement of the seal + labour.
They didn't follow the TSB. Bummer.
edit: actually, I may have mixed up my TSBs. I can't find the one that specifically addresses that issue. Hmmm...
Old 04-23-2016, 03:49 AM   #16
Ok, here's the best reference to the change in the switches
http://www.ft86club.com/forums/showp...7&postcount=61
Old 04-23-2016, 04:14 AM   #17
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I think this is an entirely different scenario lol
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 04-23-2016, 09:30 AM   #18
nanofamous
nanofamous's Avatar
Drives: 2013 scion FR-S 6MT Firestorm
Did you have the door switches replaced? The main problem is the early switches dropped the windows 20mm. A few months into production they cut the index in half. That cured it.
I will definitely mention that to the service tech. I have an appt next saturday.
Sent from my SAMSUNG-SM-N910A using Tapatalk
nanofamous is offline   Reply With Quote
The Following User Says Thank You to nanofamous For This Useful Post:
Ultramaroon (04-23-2016)
Old 04-23-2016, 09:50 AM   #19
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Mines doing same, I have an ext waranty. They said take it in and they'll pay only if window is off track. If it's a trim thing they won't. Will only cover mechanical seal breakdown
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 04-23-2016, 01:42 PM   #20
I don't think the door seal issue was covered in a TSB. My bad. But I assure you the root cause is excessive window indexing coupled with the window itself closing too tightly against the seal.
@stockysnail, how is yours holding up after you updated the switches?
DaJo (04-23-2016)
Old 04-23-2016, 04:11 PM   #21
stockysnail
Just the tip
stockysnail's Avatar
Mine is working great after I replaced the switches and the door molding. I never switched the molding on the passenger side as it wasn't as bad but it's not getting any worse on that side after the switch. Overall I'm very glad I did it.
The Following User Says Thank You to stockysnail For This Useful Post:
Old 05-29-2016, 08:59 PM   #22
nanofamous
nanofamous's Avatar
I got mine replaced a couple weeks ago... all good for now.
Tint shop butchered my window seals BRZ FTW Cosmetic Modification (Interior/Exterior/Lighting) 14 06-10-2015 01:51 AM
do the direct injector seals need to be replaced? Astroboy Engine, Exhaust, Transmission 17 04-15-2015 07:01 AM
Injector Seals went Bad while tuning my car whitefrs Forced Induction 128 08-20-2013 01:19 PM
Bad window seals? Dzeremijs Issues | Warranty | Recalls / TSB 18 10-26-2012 04:24 PM
