Drives: None
do the direct injector seals need to be replaced?
like somebody mentioned that the spark plugs need to be changed after 60k miles, i was wondering if the direct injection seals would need to be replaced as well?
my biggest anxiety is about driving this car and having one of my direct injector seals going out. my car is turbocharged with an Avo kit, and i pray that that wont kill the lifespan on the seals. |
Well, like they say in the old country ..... if they ain't broke, why fix em .... ??
humfrz |
#3 | |
Shift it or lose it
Drives: 2014 FRS, 2003 Celica GT
With the failure rates i've seen on those seals from just this forum plus 60,000 miles and you're running boost. Just change them and feel good that they are new! |
Drives: 2013 Asphalt 6spd
unless you don't hook up your hpfp lines correctly and get to host a roadside BBQ... no pressure.
#5 | |
Shift it or lose it
What about if you get mugged while walking down the street? What if the dealership actually covers that under warranty?! For obvious reasons if you don't have any experience working with *eyerolls* High fuel pressure. Then take it to someone who can do the repair properly. I work on 30,000psi fuel systems everyday as a tech services engineer. the direct injector seals are not really something I would consider difficult to replace. Maybe a little bit time consuming at best because of their location.
#6 | |
Drives: 86
The procedure for replacing DI seals is such a PITA that many shops and dealerships will refuse to do the work unless symptoms of failure are obvious. So just keep an eye on any CELs or audible knocking.
#8 | |
Drives: 2015 Series.Blue
This. If you think it's going to be some easy thing to do, you're gonna have a bad time. Watch some videos on people actually doing the repair and see that it's not something you'll want to do unless absolutely necessary. |
Drives: None
The question I'm asking is if the di seals should be replaced at a curtain amount of miles? How often am I suppose to swap them out?
#10 |
Drives: '16 WRX, CBR1000RR
The answer that you've been given is no, they don't need to be replaced at any certain mileage Unless symptoms of their failure start showing up.
If your tune is right I don't think you'd ever realistically need to change them.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
#11 |
Drives: None
thanks. i really appreciate it. i have bad anxiety and i worry about everything, and when i heard about all these injection failures, my anxiety sky rocketed. i remember i would also abuse this car in last summer in Texas weather with the turbo kit without checking the oil temps nor water temps, and no oil cooler.
#12 | |
#13 |
Drives: None
#14 |
not playing cards
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 12:35 PM |
| Injector Seals went Bad while tuning my car | whitefrs | Forced Induction | 128 | 08-20-2013 12:19 PM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 09:31 AM |
