Old 04-22-2016, 09:01 PM   #1
nanofamous
nanofamous's Avatar
Drives: 2013 scion FR-S 6MT Firestorm
Window seals
First of all.. there are so many topics it would be hard to search them all... so,
You know how the windows roll down and up when you open and close the doors.. does anyone have the same thing as me?
On my driver side when the window rolls back up it catches the seal and pulls it up.
Would this be a warranty fix possibly?
nanofamous is offline   Reply With Quote
Old 04-22-2016, 09:04 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I believe so. If your in warranty just take it in.
Old 04-22-2016, 09:08 PM   #3
nanofamous
nanofamous's Avatar
Right on. Thanks for the feedback
Sent from my SAMSUNG-SM-N910A using Tapatalk
Old 04-22-2016, 09:41 PM   #4
navanodd
Drives: 2013 BRZ Sport-tech WRB
Depending on how severe it is, the window seal may just be dried out and need some silicone love.
navanodd is offline   Reply With Quote
Old 04-22-2016, 09:44 PM   #5
Well, now, there ya got it @nanofamous....... both solutions in 2 posts .......
I think we may have a record here ........
Old 04-22-2016, 09:51 PM   #6
nanofamous
nanofamous's Avatar
It has been doing it for a bit now.. you can definitely see where it catches
Old 04-22-2016, 10:04 PM   #7
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
if you search 'window seals' you'll get what you're looking for. Here are a couple:
http://www.ft86club.com/forums/showthread.php?t=11682
http://www.ft86club.com/forums/showthread.php?t=68731
shiumai is offline   Reply With Quote
Old 04-22-2016, 10:31 PM   #8
nanofamous
nanofamous's Avatar
Thanks for the heads up @shiumai
Old 04-22-2016, 11:33 PM   #9
CatScan
Almost every problem with the 13's have been addressed. "Take it to the shop" is the best answer.
CatScan is offline   Reply With Quote
Old 04-23-2016, 12:18 AM   #10
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Mine was smooshed up on the driver side (a friend of mine couldn't stop giggling when I described the issue this way) and it was fixed at the dealership under warranty. Take it in, show them the issue, and they should fix it.
Nevermore is offline   Reply With Quote
Old 04-23-2016, 12:19 AM   #11
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I've taken mine to the Subaru shop 2-3 years back under warranty and the problem did not go away.
The best solution is to lightly rub some 303 Aerospace Protectant on the seals or a type of silicone based gel. It is not a perm fix, but it will have to do as the dealer will only replace the same exact part on there... The problem will come back.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 04-23-2016, 12:23 AM   #12
CatScan
If you think there is an issue, tell the dealer. At least make sure they note your complaint.
Old 04-23-2016, 01:29 AM   #13
Did you have the door switches replaced? The main problem is the early switches dropped the windows 20mm. A few months into production they cut the index in half. That cured it.
Old 04-23-2016, 01:32 AM   #14
DaJo
FT86Club Vancouver
DaJo's Avatar
I don't believe they replaced my switches... =/
All I saw on the warranty invoice was the replacement of the seal + labour.
2000 MR-S 5MT
2010-2012
Tint shop butchered my window seals BRZ FTW Cosmetic Modification (Interior/Exterior/Lighting) 14 06-10-2015 12:51 AM
do the direct injector seals need to be replaced? Astroboy Engine, Exhaust, Transmission 17 04-15-2015 06:01 AM
Injector Seals went Bad while tuning my car whitefrs Forced Induction 128 08-20-2013 12:19 PM
Bad window seals? Dzeremijs Issues | Warranty | Recalls / TSB 18 10-26-2012 03:24 PM
