Old 04-18-2016, 10:39 PM   #15
chargedup
Drives: SC BRZ
Originally Posted by mav1178 View Post
they won't care.
The inspection part is only to verify the VIN. 99% of the time they won't care.
Just have it inspected at the DMV, takes longer but it will be less hassle free as they have zero authority to make judgment calls on whether it is in violation or not.
-alex
Perfect. Thanks man
chargedup is offline   Reply With Quote
Old 04-19-2016, 01:54 AM   #16
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Slightly unrelated.
Anyone know if they still do a sniffer test? I was gonna gut the oem cat weld in some pipe. Was wondering if it would pass lol I know it would pass the visual.
Sent from my SM-G900V using Tapatalk
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 04-20-2016, 02:22 AM   #17
scarfo
Drives: gts 86
I used an oem cat with an additional euro 4 cat welded into to pass the Aussie version of that test.( which is based off the USA version). My normal setup is a 200cell front pipe, just for visuals basically
scarfo is offline   Reply With Quote
The Following User Says Thank You to scarfo For This Useful Post:
dj2020 (04-20-2016)
Old 04-20-2016, 04:55 AM   #18
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Phantobe View Post
Slightly unrelated.
That will throw a CEL which will fail, not sure if a tune disabling the CEL will pass or not. I believe later OBD2 cars don't get sniffed, they just plug in and check the ECU for emissions readiness.
ineedyourdiddly
Old 04-20-2016, 04:04 PM   #19
Phantobe
Phantobe's Avatar
Well running catless without a tune is kinda silly, I'd be using an OFT which covers up the CEL...
So I'm just wondering if it passed the emissions readiness, would be some good information to know.
WORKS Stage 2 Turbo Kit - Now CARB Compliant/SMOG Legal WORKS Forced Induction 415 10-16-2021 06:55 PM
CARB Compliant WORKS Turbo Kits - Now Available! 50-State Smog Legal! WORKS Forced Induction 47 01-13-2017 05:40 PM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 07:01 PM
Smog pass turbo frs johneastvold Southern California 25 10-02-2015 09:29 PM
Smog check and visual inspection help Corradooo Northern California 24 05-20-2014 12:57 AM
