Old 04-17-2016, 12:51 PM   #15
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Presuming that both cars have the same OEM battery and the only real difference is all the electronic goodies the BRZ has I can only conclude that one or more of those goodies is creating a parasitic draw that drains batteries faster than the FRS. Hardly scientific and I can not prove my theory but there it is.
Its the underglow everyone keeps installing.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
86kahl (04-17-2016), Tcoat (04-17-2016)
Old 04-17-2016, 12:53 PM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Dude! That is not what they mean when they say "do acid".
....sounds like youve done it before mr. Coat.
Old 04-17-2016, 01:27 PM   #17
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
2hr of music and mine dies. 1.5yrs old. POS
Old 04-18-2016, 09:52 PM   #18
Pat.Thornton
Pat.Thornton's Avatar
Drives: 2014' 86
And how would you know????
Lol
Pat.Thornton is offline   Reply With Quote
The Following 2 Users Say Thank You to Pat.Thornton For This Useful Post:
cdrazic93 (04-19-2016), PandaSPUR (06-01-2016)
Old 04-18-2016, 10:54 PM   #19
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Just bought a new one last week. Original battery from 2013 model. Worked fine on cold start, was only getting hard to turn on heatsoak. I'd buy it again if not for the convenience of Costco
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 04-19-2016, 07:05 AM   #20
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
WOW you got four years out of a battery! Thats pretty damn good. I've not been able to get three years out of a battery. I just concluded they are all pos. The biggest problem I've seen with batteries over the decade is corosion. I've not noticed any in the FRS but I've only had it 5 months
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 04-19-2016, 07:19 AM   #21
I'm at about the 4 year mark with mine as well, no issues, but I have averaged 48 miles per day since purchased (with most weekdays being around 90) so it stays pretty well charged. Also, I almost never run accessories with the engine off.
Admittedly, I hadn't checked mine in a while, guess I need to add that to my to-do list for this weekend.
Ultramaroon (04-19-2016)
Old 04-19-2016, 08:45 AM   #22
In the reverse of this situation I have not had to replace a battery in a car in almost 20 years and have been impressed with how they have stayed corrosion free.
Old 04-19-2016, 10:10 AM   #23
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
I have completely abused this battery. It's been run flat probably more than 2 dozen times. Jump started or charged as many.
This is the original battery when I bought the car, 2012. So in a few weeks 4 years on.
Still jump starts fine and will hold enough charge to start for about a week.
Anyone else satisfied with the OEM battery? Seen a lot of negative things about it but from my experience it aint half bad.
Based on your description above it sounds like you DO HAVE a problem with your battery in the first place. Or you are just not too bright screwing up in a way that can cause you to "run flat probably more than 2 dozen times".
That's kind of like saying "The flame retardant in my racing suit works Great! IN the dozen times I have had to extinguish it while on fire, it went right out".
justatroll is offline   Reply With Quote
Old 04-19-2016, 11:16 AM   #24
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Mine lasted 1.5 yrs... then it started leaking and fucked stuff up... replaced with a shorai lw battery, because racecar
Cartman is offline   Reply With Quote
Old 04-19-2016, 11:32 AM   #25
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Mine lasted 4 months, then it started leaking everywhere, And i said hell no get that piece of crap out of there and then had to clean the tray and around the tray very thoroughly to ensure it didn't eat anything. And I installed a Die hard(worked at sears at the time), and i didnt expect this battery to last very long, but it sat for 5 months and through winter and I took the cover off and it started right up, didnt even crank slow.
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
ZionsWrath (04-19-2016)
Old 04-19-2016, 01:28 PM   #26
Still on my factory battery. Strong as day-one.
Old 04-19-2016, 02:27 PM   #27
ZionsWrath
Thanks
ZionsWrath's Avatar
My car sits a lot and the battery goes flat.
Not sure how the is similar to me being on fire multiple times. Flamer
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
justatroll (04-19-2016), Tcoat (04-19-2016)
Old 04-19-2016, 03:01 PM   #28
justatroll
justatroll's Avatar
I'm not sure that having a battery that survives going flat a lot means it is a good battery.
I'll try a different analogy:
"Those run flats are the best tire I've ever had! The two dozen times I have had a flat, the sidewalls held up just fine!"
Best two way dash cam that uses car battery and it's own battery? azynneo Electronics | Audio | NAV | Infotainment 14 01-22-2016 10:23 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 08:55 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
