Old 04-11-2016, 12:09 PM   #3823
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Did this happen to your charger pulley?
Originally Posted by mscamp02 View Post
Pullet is toast to S/C is toast screws backed out. Actually was kinda lucky because I was doing a random check and noticed the pulley wobbling, well while I was watching it wobble trying to remember how I had to attach it or if it was a bearing or something going out it snapped the last bolt or two that was holding it causing it to jump and grind.
I got the pulley and belt off after pulling the main bracket off its mounts. Looks like I'll have to reflash back for a while until I can get a new pulley, no damage to s/c at least.
FRSTRM is offline   Reply With Quote
Old 04-17-2016, 10:39 PM   #3824
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
anyone have a leak oil issue on the reservoir? i think mine leak from the top of the reservoir, either the cap or from the washer of the bolt that the oil returned into the reservoir.
scionfr_s is offline   Reply With Quote
Old 04-18-2016, 11:00 PM   #3825
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Yep! I replaced the copper seals on the line and cleaned up the gaskets on the cap and it went away.
D-VO is offline   Reply With Quote
Old 04-18-2016, 11:03 PM   #3826
D-VO
I'm still using the factory header overpipe and frontpipe. Recently I caught some muffler packing coming out of the exhaust. I took everything apart and found the cat converter was empty.
LOL! POWWAAAAAA!!!!!!!
Old 04-20-2016, 11:13 AM   #3827
mscamp02
Drives: 2013 FRS
It was on the charger pulley, I received a new pulley from KW and was able to install it earlier this week and I am now back to 100%.
mscamp02 is offline   Reply With Quote
Old 04-20-2016, 11:14 AM   #3828
mscamp02
Drives: 2013 FRS
During installation I had to replace a copper seal because there was a slight notch in the one that came with it which caused a minor leak. Once I switched that out it has been great for about 5k miles.
Old 04-24-2016, 12:52 PM   #3829
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
that's funny this just happened to me recently.... the bolt holding the pulley to the sc snapped.... so bizarre. I had to send the whole sc and bracket to them so they can inspect the sc and replace the pulley, bolts, and a new belt. everything is free which is awesome, but i had to pay for shipping there.
also... for those who needs the belt...:
https://www.mrosupply.com/synchronou..._gates-rubber/
pgranberg11 is offline   Reply With Quote
Old 04-25-2016, 01:48 PM   #3830
mscamp02
Drives: 2013 FRS
My belt was intact and they ended up sending me the new pulley and bolts for 50 dollars because I didn't want to deal with trying to claim warranty which I think worked out really well since I got it back up and running in a couple of days and didn't have to send out anything. Definitely looks like a point of concern but I am regularly inspected that pulley now as a watch out.
Old 04-25-2016, 03:38 PM   #3831
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
I have two of the smaller belts for sale if anyone needs some spares (IF you're using the old drivetrain). They don't fit with the larger pulleys so I have no use for them unless I get bored and use the smaller ones for the hell of it.
Old 04-25-2016, 11:35 PM   #3832
86Tony
Drives: 2015 AOZORA EDITION
lol all these belts snappin is a joke
86Tony is offline   Reply With Quote
Old 04-26-2016, 06:16 AM   #3833
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
i've pretty much given up on the kraftwerks system with all of my 4 broken belts. i could never get the system tensioned correctly, even after following kraftwerks instructions. they decided to give me a complete refund for the entire system so i can buy something else entirely. i will never in my life go with a manually tensioned system ever again.
morswestford is offline   Reply With Quote
Old 04-26-2016, 06:26 AM   #3834
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
If no one has seen this thread yet. The OP lays out all the issues with the kit and a few ways to work around them.
a bit on supercharger drive systems and the Kraftwerks kit.
http://www.ft86club.com/forums/showthread.php?t=104382
Freeman is offline   Reply With Quote
Old 04-26-2016, 06:28 AM   #3835
Freeman
Freeman's Avatar
Sadly not a joke. It's what the kit is now known for
Old 04-26-2016, 08:10 AM   #3836
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
The kit needs an auto pulley tensioner. The belt heats up and the belt is no longer tight enough. To cold and it's tomuch tension. For this very reason is why cars main serpentine belt as a auto pulley tensioner.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
