Old 04-14-2016, 05:19 PM   #1
VictorKassil
[||•(==(86)==)•||]
VictorKassil's Avatar
Drives: WRB Subaru BRZ Series.Blue
Send a message via Yahoo to VictorKassil
P0175 code after installing intake
I just installed a new intake on my car and now I keep getting the system too rich bank 2 code and a rough/low idle. How can I fix this without changing back to the stock intake?
"Guys, I'm bringing the party to you!"
-Tony Stark
______________________________________
VictorKassil is offline   Reply With Quote
Old 04-14-2016, 05:35 PM   #2
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Tune or switch to aftermarket intake with same oem charge pipe diameter. What other mods are on?
Toyarzee is offline   Reply With Quote
Old 04-14-2016, 05:45 PM   #3
VictorKassil
[||•(==(86)==)•||]
Just a Works axleback. Could there be a problem with the MAF?
-Tony Stark
Old 04-14-2016, 05:55 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Did you put the maf sensor in the correct orientation? It can only go one way? Did you drop or touch the maf?
Disconnect the battery for awhile and keep the key in the on position, see if you can reset the code and then check if it comes on again
Old 04-14-2016, 08:22 PM   #5
VictorKassil
[||•(==(86)==)•||]
It goes on one way.
-Tony Stark
Old 04-14-2016, 08:36 PM   #6
steve99
Drives: FT86
It goes on one way.
which intake do you have
Another CEL code whitefrs Forced Induction 20 11-27-2019 12:27 PM
Perrin Cold Air Intake CEL Code? MDS86 Engine, Exhaust, Transmission 9 02-05-2016 01:13 PM
Takeda aFe intake cause CEL? Code: P0171. Figo Engine, Exhaust, Transmission 4 11-20-2014 02:45 PM
Installing the TRD Cold Air Intake scottsampaio.com Engine, Exhaust, Transmission 23 11-16-2014 02:52 PM
P0172 Code with Injen Intake, will EcuTek tune help? ron_jeremy Engine, Exhaust, Transmission 0 11-27-2012 12:22 PM
