Old 04-13-2016, 12:17 PM   #15
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by SPCorBUST View Post
Without one the battery moves around as you drive, it's only held by the terminals. If you move to a Shorai or Braille those kits still have a cradle or some bracing that acts as a tie down. Since I'm going to have to use one, I'd prefer it be the STI one and not some custom brace. I'm not after the lightest battery around, I'm after a lighter battery that I can still use the tie down with.
I just tend to find a battery that fits snuggly in the space (making it very hard for the battery to move, even did a few over crest jumps with no negative impact.. but that was in my is300, tie down still on the BRZ as I haven't had to change the battery yet, I'll keep it there but if it didn't fit I wouldn't be worried and just toss it)... that a bit more of what I meant as a Wee part
fumanchu1 is offline   Reply With Quote
Old 04-13-2016, 01:09 PM   #16
nunonuna
nunonuna's Avatar
Here's the picture of how I did.
Never move around. Not even 1/4"
Basically, you switch two tie rod/bolt each other and bend the longer one as shown in the picture. As you can see, if you lay the battery to mount, one of the holes for the tie rod sits above the battery. That is why I bent longer one. It is tricky to tight the nut, but it is doable.
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
SPCorBUST (04-13-2016)
Old 04-13-2016, 04:40 PM   #17
SPCorBUST
SPCorBUST's Avatar
How did you get the terminals that way? Some extension?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 04-13-2016, 04:51 PM   #18
nunonuna
nunonuna's Avatar
No need extension. It is long enough to reach both terminals. As far as I remember, you only need to pop out the tie/clip or whatever its called as shown in below pic.
The Following 2 Users Say Thank You to nunonuna For This Useful Post:
fumanchu1 (04-13-2016), SPCorBUST (04-14-2016)
Old 04-14-2016, 11:15 PM   #19
Poodles
Drives: 2015 Series.Blue
Originally Posted by fumanchu1 View Post
That's because you don't need a battery tie down
1) You'll fail tech at any race track.
2) It's a fire hazard.
3) Abrasion of the battery case is bad, mkay?
4) Having wire failures because the copper work hardens from the constant bending because battery is moving.
Overall, it's just stupid to say that it's not needed. Batteries are literally bombs and should be treated as such.
The Following 5 Users Say Thank You to Poodles For This Useful Post:
Dream20b (04-15-2016), funwheeldrive (10-27-2019), JD001 (04-15-2016), mixtape (04-15-2016), SPCorBUST (04-15-2016)
Old 04-15-2016, 11:06 AM   #20
fumanchu1
1-already said it was needed in some circumstances, tracking being one of them
2-4 if you have a battery that fits snuggly into the space, it will not move hence will not bend, will not cause abrasions and will not be a fire hazard. mkaaaayyyyy???!!?
(I did say it's recommended but not needed and if one follows the definitions I am correct in my statement) that being said, yes you should keep it on. If you haven,t notice yet that I was somewhat trolling/playing devil's advocate on this subject.
But I also had 2 cars with no tie down and nothing ever happened
Batteries are not bombs also, having seen several explode over the course of my life as well as actual explosives, they are not even close... that being said, having a battery blow up in your face is not a fun time.
Old 04-15-2016, 11:41 AM   #21
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
Posts like this cause kids to do dumb things and ruin cars
G-Man is offline   Reply With Quote
The Following User Says Thank You to G-Man For This Useful Post:
Old 04-15-2016, 11:44 AM   #22
OkieSnuffBox
Drives: '23 BRZ Limited
Please don't any listen to poor choice in facial hair.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 04-15-2016, 11:45 AM   #23
fumanchu1
Natural selection of sorts I guess.
If I say you can fly and you try it, I'm not the one at fault... you and your stupidity are :P
The Following User Says Thank You to fumanchu1 For This Useful Post:
TruRace (04-16-2016)
Old 04-15-2016, 11:51 AM   #24
fumanchu1
probably a good idea that you didn't and ill agree with that.
Old 04-15-2016, 02:05 PM   #25
Poodles
"Snuggly" isn't tight enough to stop abrasion. Unless there is a clamping force, it's not tight enough.
Anecdotal evidence isn't evidence at all. But if you want to play that game, I've had issues in some of my older cars that lacked a battery tie down. If it wasn't required, car makers wouldn't use them as it's counter to cost savings.
That's the equivalent of saying a firecracker isn't a bomb when by definition they are.
Nobody likes a devil's advocate...
The Following User Says Thank You to Poodles For This Useful Post:
G-Man (04-15-2016)
Old 04-15-2016, 02:41 PM   #26
G-Man
G-Man's Avatar
The Following 2 Users Say Thank You to G-Man For This Useful Post:
86kahl (04-15-2016), fumanchu1 (04-15-2016)
Old 04-15-2016, 02:42 PM   #27
fumanchu1
Ill accept that statement 😂
Sent from my SGH-M919V using Tapatalk
G-Man (04-15-2016)
Old 04-15-2016, 10:45 PM   #28
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
86kahl is offline   Reply With Quote
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Engine, Exhaust, Transmission 61 09-30-2016 11:24 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Installing Shorai Lightweight Battery and #Lighterisbetter CNC Machined Tray SaVaGeRaIn DIY (Do-It-Yourself) Guides 2 08-03-2014 08:55 AM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Engine, Exhaust, Bolt-Ons 18 06-04-2014 01:07 PM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Tracking / Autocross / HPDE / Drifting 5 12-07-2013 02:01 PM
