Old 04-12-2016, 04:27 PM   #1
SPCorBUST
SPCorBUST's Avatar
Lightweight battery that fits the stock tray and tie down?
My battery died and I need a replacement. I currently have the STI battery tie down and I'd like to continue using it, which seems like it severely limits my lightweight battery options to the point of nothing. (so far as I've seen)
As far as weight is concerned, I'd like it to be lighter, but extreme lightweight isn't necessary (although certainly welcome) - it just needs to fit the stock parts.
Anyone know of a battery that fits the bill?
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 04-12-2016, 04:42 PM   #2
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Battery tie down!? You mean a wee part (grab part, toss it, make weee noise while tossing)
fumanchu1 is offline   Reply With Quote
Old 04-12-2016, 05:19 PM   #3
JD001
JD001's Avatar
Drives: Subaru BRZ
I am biting my tongue.
Old 04-12-2016, 06:01 PM   #4
fumanchu1
and why is that exactly if you care to elaborate?
Old 04-12-2016, 06:04 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Because he thinks you're saying that you don't need a battery tie down.
Originally Posted by humfrz
I'm old and lazy
Old 04-12-2016, 07:14 PM   #6
s14sleepyeyez
Drives: 2013 Argento Scion FR-S
http://www.ft86speedfactory.com/ft-8...l#.Vw2BYY-cGUk
s14sleepyeyez is offline   Reply With Quote
Old 04-12-2016, 07:38 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by s14sleepyeyez View Post
that doesnt use the factory tie down though like OP was looking for
Old 04-12-2016, 08:24 PM   #8
KC Machine w/ Shorai.
Old 04-13-2016, 11:11 AM   #9
fumanchu1
That's because you don't need a battery tie down
Old 04-13-2016, 11:19 AM   #10
SPCorBUST
SPCorBUST's Avatar
Without one the battery moves around as you drive, it's only held by the terminals. If you move to a Shorai or Braille those kits still have a cradle or some bracing that acts as a tie down. Since I'm going to have to use one, I'd prefer it be the STI one and not some custom brace. I'm not after the lightest battery around, I'm after a lighter battery that I can still use the tie down with.
Old 04-13-2016, 11:45 AM   #11
Clipdat
Proud of BOXER
Clipdat's Avatar
I always thought it was a saftey issue. In the result of a crash, you don't want the battery shifting/falling over and the wires getting disconnected and grounding out/sparking.
Also I found this via google: "A battery doesn't like excessive vibration. Vibration can shorten it's life."
I'm old and lazy
Old 04-13-2016, 11:58 AM   #12
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
+1
Love mine.
http://store.kcmachine.com/products/...ckage-preorder
Old 04-13-2016, 12:11 PM   #13
nunonuna
nunonuna's Avatar
With slight modification of longer stock battery tie bolt, you can mount the battery flat like I did, but I have braille 15 lbs AGM & cusco battery tie which is stock size also. It fits perfectly by side mounting.
nunonuna is offline   Reply With Quote
Old 04-13-2016, 12:13 PM   #14
fumanchu1
I can kinda see the use in a crash (although there are more things to worry about in such a scenario )
Definitely a use for them and they are recommended but not needed (hell I've done crest jumps a few time with no negative issues).
I'm curious about the vibration quote from google though, I'll take a look
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Engine, Exhaust, Transmission 61 09-30-2016 11:24 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Installing Shorai Lightweight Battery and #Lighterisbetter CNC Machined Tray SaVaGeRaIn DIY (Do-It-Yourself) Guides 2 08-03-2014 08:55 AM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Engine, Exhaust, Bolt-Ons 18 06-04-2014 01:07 PM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Tracking / Autocross / HPDE / Drifting 5 12-07-2013 02:01 PM
