| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2017 CWP BRZ Performance Package
OEM STI wheels + Spacers
Hate to start a thread about this, but I'm not getting enough answers and not enough posts about this topic, so I'm doing a shot in the dark here.
Did a bunch of searches and found a few people running 20/25 or 25/30 spacers on the series blue STI wheels. However, a forum user in the Series blue registry thread was saying that the indentation for weight reduction on the sti wheels are not as deep, and that 20mm spacers do not work for them. Can anyone confirm this? I already bought 25mm spacers so I need to know before I can purchase another pair. |
#2 |
Drives: 14 WRB BRZ Limited MT
Different brand spacers give different sized lugs that might stick out.
Here are some pics of when I had H&R 20/25's. Real close on the 20, but you should be fine with the 25.
#3 |
Thanks for the pics... I'm not even exactly sure how the indentations interfere but I think the studs on the spacers is what's supposed to be bad, not necessarily the part that bolts on to the hub?
#4 |
Drives: 86 GTS
#5 |
#6 |
http://www.ft86club.com/forums/showthread.php?t=78559
Apparently I didn't search enough... Thanks to iLaw for pointing me in the right direction |
#7 |
For future reference,
20mm spacers that work are H&R confirmed by @iLaw and B2Design's spacers confirmed by Charles from B2Design |
#8 |
Drives: 2015 BRZ Series Blue WRB
Hey Guys, i have a series blue with STI wheels, would the spacers below fit? im thinking on doing 25mm all around:
http://www.ft86speedfactory.com/h-r-...l#.Vw5YEfkrKWg Just want some input on the quality of this product and if you have any other recommendations, thanks. @spicyricecake ?? |
#9 | |
If you want hub centric go with B2AutoDesign or Perrin spacers. If you are going to lower the car, I recommend doing 25/30 instead since 20/25 tucked too much for me after lowering (flush on stock height though) |
#10 | |
#11 |
#12 | |
After seeing your pics in your build thread, im undecided between 20mm all around or 25mm all around :S |
#13 | |
I'd still say 25 front and 30 rear or 25mm all around for lowered series blues |
#14 |
Drives: 2015 Subaru BRZ WRB
I ran 38mm all around, if you are low this is the best fit.
| Spacers on OEM wheels? | BRZlimited | BRZ First-Gen (2012+) — General Topics | 13 | 04-11-2014 07:47 PM |
| Spacers/drop for OEM wheels | poorsche | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 03-24-2014 10:00 PM |
| Stock Wheels Need Spacers? | theom | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-17-2013 11:49 AM |
| Debating on wheels . which spacers? | Mrqb22 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 10-04-2012 09:28 PM |
| Spacers with Stock Wheels | Starscream15 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-05-2012 01:31 PM |
