Old 04-11-2014, 03:15 PM   #1
BRZlimited
BRZlimited's Avatar
Drives: 2013 Subaru BRZ limited
Spacers on OEM wheels?
What are your views on this? I'm debating ordering H&R spacers for my car to use with my OEM. Thought I'd go with 30mm in the back and 25mm in the front. My goal is to have a more flush look without having to buy wider tires. What's everyone's view points on this?
BRZlimited is offline   Reply With Quote
Old 04-11-2014, 03:19 PM   #2
DAEMANO
Time Traveller
http://lmgtfy.com/?q=spacer+stock+site%3Aft86club.com
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
DavidBob (04-12-2014), sshole (04-11-2014)
Old 04-11-2014, 03:30 PM   #3
BRZlimited
BRZlimited's Avatar
Originally Posted by DAEMANO View Post
I'm aware of how to use Google. And did pleanty of that to come up with the set up that I decided. I created the thread to ask my fellow friends on here what they thought of my own setup and to get some additional input from friend. Thank you for your help though.
Old 04-11-2014, 03:40 PM   #4
sshole
I'm not your friend, buddy.
sshole is offline   Reply With Quote
The Following User Says Thank You to sshole For This Useful Post:
DAEMANO (04-11-2014)
Old 04-11-2014, 03:58 PM   #5
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
I saw someone post that 30mm was too wide. I think they went near flush with 25 mm & 20 mm. YMMV as I have no personal experience.
ntron1 is offline   Reply With Quote
Old 04-11-2014, 05:01 PM   #6
idanvan
idanvan's Avatar
Drives: WRB BRZ
I have spacers I can sell you. 20mm front, 25mm rear. Flushes out the OEM wheels well. PM me if you want pics.
idanvan is offline   Reply With Quote
Old 04-11-2014, 05:32 PM   #7
dsgerbc
Drives: BRZ(sold), STI
Make sure you buy extended studs.
dsgerbc is offline   Reply With Quote
Old 04-11-2014, 05:50 PM   #8
dbrandt01
Drives: none
I was recommended the set up you're wanting to go when I lowered mine on coilovers. That being said, I know the dangers of them from the truck world if you don't spend the money and buy extended studs. So, I'm choosing not to run spacers on this car.
Not saying people don't have problems. There's hundreds I'd say on this site that run them fine. I just don't like them personally.
dbrandt01 is offline   Reply With Quote
Old 04-11-2014, 06:48 PM   #9
BRZlimited
BRZlimited's Avatar
I already ordered them from H&R. Thanks for the offer though. They came with studs pré built in.
Old 04-11-2014, 07:03 PM   #10
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
Which ones did you get? I just installed a set myself.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 04-11-2014, 07:33 PM   #11
BRZlimited
BRZlimited's Avatar
How'd you like them? Notice anything different in the feel? What size did you get?
Old 04-11-2014, 07:35 PM   #12
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Why pay for spacers when you can buy cheap 17x8's with an agressive offset and use your stock tires? Seriously $200 spacers or $400 wheels? Just get the $400 wheels by saving a little longer...
Old 04-11-2014, 07:37 PM   #13
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
http://www.ft86club.com/forums/showp...7&postcount=34
That post shows the comparison between stock and 25mm spacers.
In that thread you can also see the difference with spacers/springs vs stock/coilovers.
Hope that helps!
PERRIN_Mladen is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Mladen For This Useful Post:
chimmy (04-12-2014)
Old 04-11-2014, 07:47 PM   #14
dp1
driving smoother faster
Drives: Sold
...wider wheels and spacers appear to increase wear of wheel bearings, since they are designed for stock components/dimensions...don't know which spacer thickness becomes too much...I'm planning to use my 12mm spacers on street and track to clear BBK...I will replace wheel bearings if/when needed...
Anyone has more experience with specific spacer thickness and excessive wheel bearing wear for twins? Perhaps with more track/AX use or higher street miles?
dp1 is offline   Reply With Quote
Spacers/drop for OEM wheels poorsche Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-24-2014 10:00 PM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 11:49 AM
Debating on wheels . which spacers? Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 10-04-2012 09:54 PM
Debating on wheels . which spacers? Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-04-2012 09:28 PM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
