Old 07-27-2015, 12:10 AM   #1
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
OEM STI wheels + Spacers
Hate to start a thread about this, but I'm not getting enough answers and not enough posts about this topic, so I'm doing a shot in the dark here.
Did a bunch of searches and found a few people running 20/25 or 25/30 spacers on the series blue STI wheels.
However, a forum user in the Series blue registry thread was saying that the indentation for weight reduction on the sti wheels are not as deep, and that 20mm spacers do not work for them.
Can anyone confirm this? I already bought 25mm spacers so I need to know before I can purchase another pair.
spicyricecake is offline   Reply With Quote
Old 07-27-2015, 01:05 AM   #2
lamune
Drives: 14 WRB BRZ Limited MT
Different brand spacers give different sized lugs that might stick out.
Here are some pics of when I had H&R 20/25's. Real close on the 20, but you should be fine with the 25.
Build:
"AWW YEA" < RIP
lamune is offline   Reply With Quote
The Following User Says Thank You to lamune For This Useful Post:
Hyper4mance2k (07-27-2015)
Old 07-27-2015, 01:33 AM   #3
spicyricecake
Thanks for the pics... I'm not even exactly sure how the indentations interfere but I think the studs on the spacers is what's supposed to be bad, not necessarily the part that bolts on to the hub?
Old 07-27-2015, 01:43 AM   #4
Juvenile
Juvenile's Avatar
Drives: 86 GTS
Unsure of what size spacers on this car, also if this is a BRZ Aozora then I believe the wheels are 7" wide where as the Jap STI ones are 7.5"
The Following User Says Thank You to Juvenile For This Useful Post:
Clipdat (04-13-2016)
Old 07-27-2015, 09:05 AM   #5
spicyricecake
Didn't even know Aozora=series blue for Canada.
Cool!
I still need to know if 20mm spacers will fit though
Old 07-28-2015, 03:15 AM   #6
spicyricecake
http://www.ft86club.com/forums/showthread.php?t=78559
Apparently I didn't search enough... Thanks to iLaw for pointing me in the right direction
Old 07-28-2015, 11:06 AM   #7
spicyricecake
For future reference,
20mm spacers that work are H&R confirmed by @iLaw and B2Design's spacers confirmed by Charles from B2Design
The Following User Says Thank You to spicyricecake For This Useful Post:
kch (07-28-2015)
Old 04-13-2016, 10:31 AM   #8
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Hey Guys, i have a series blue with STI wheels, would the spacers below fit? im thinking on doing 25mm all around:
http://www.ft86speedfactory.com/h-r-...l#.Vw5YEfkrKWg
Just want some input on the quality of this product and if you have any other recommendations, thanks.
@spicyricecake ??
Jfheisenberg is offline   Reply With Quote
Old 04-13-2016, 12:52 PM   #9
spicyricecake
@spicyricecake ??
I believe H&R come with extended studs, and they fit.
If you want hub centric go with B2AutoDesign or Perrin spacers.
If you are going to lower the car, I recommend doing 25/30 instead since 20/25 tucked too much for me after lowering (flush on stock height though)
Old 04-13-2016, 01:02 PM   #10
Jfheisenberg
Im already lowered (mild) with RCE yellow springs. Its about 0.8 inches low.
Old 04-13-2016, 01:33 PM   #11
spicyricecake
couldn't say about 0.8 inches. I was 1.5 inches lowered I think and it tucked a lot. What's your camber? I'm at -2 front -3 rear
Old 04-13-2016, 01:35 PM   #12
Jfheisenberg
Not sure what is my camber now. Im getting an alignment this friday because i got the rce yellow springs installed 3 weeks ago.
After seeing your pics in your build thread, im undecided between 20mm all around or 25mm all around :S
Old 04-13-2016, 02:25 PM   #13
spicyricecake
I doubt your camber will be as much as mine with springs at 0.8 inches. Do you plan on going coils and do you care if it pokes a little?
I'd still say 25 front and 30 rear or 25mm all around for lowered series blues
Old 04-13-2016, 02:41 PM   #14
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
I ran 38mm all around, if you are low this is the best fit.
irax is offline   Reply With Quote
Spacers on OEM wheels? BRZlimited BRZ First-Gen (2012+) — General Topics 13 04-11-2014 07:47 PM
Spacers/drop for OEM wheels poorsche Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-24-2014 10:00 PM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 11:49 AM
Debating on wheels . which spacers? Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-04-2012 09:28 PM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
