Old 04-12-2016, 05:02 PM   #813
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Urmyson View Post
Serial
Resoldering it didn't help. Right now I don't think its engaging the esc at all. Not sure where to go from here. The procede software reads the rpm's and and throttle.
If you have the serial version modify as I stated above for the fuel control.
Installed Mods:
Old 04-12-2016, 05:25 PM   #814
Urmyson
Yep I tried that still no luck though, i'm surprised looks like everything is connected correctly.
Urmyson is offline   Reply With Quote
Old 04-12-2016, 05:34 PM   #815
Urmyson
Is there a firmware update that I could try?
Old 04-12-2016, 05:40 PM   #816
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
I am up and working. Batteries are already getting stronger. I have no relay so I will have to be careful when I turn things off. But all is working well.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following 2 Users Say Thank You to brzaapi For This Useful Post:
Lord09 (04-12-2016), Sojhinn (04-12-2016)
Old 04-12-2016, 05:42 PM   #817
DAEMANO
Time Traveller
Hey glad to hear it. Fun stuff man.
Old 04-12-2016, 05:50 PM   #818
Lord09
Drives: 2015 BRZ
Serial
Did you set the output channel correctly?
http://www.ft86club.com/forums/showp...postcount=9373
Lord09 is offline   Reply With Quote
Old 04-12-2016, 06:06 PM   #819
Urmyson
It was set to output 4 and I changed it to output 1. So I should be using output 3, because I have the plastic one.
Old 04-12-2016, 06:07 PM   #820
Sojhinn
Sojhinn's Avatar
Connect your computer and see if the square is moving to the right and up.
Installed Mods:
Old 04-12-2016, 06:33 PM   #821
Urmyson
The blue square moves up/down and over. Output 3 didn't give me any love though.
Old 04-12-2016, 06:34 PM   #822
Sojhinn
Sojhinn's Avatar
And just to confirm... When you are driving around that square is moving on its own?
Installed Mods:
Old 04-12-2016, 06:45 PM   #823
Urmyson
Yep it moves with the RPM's and Throttle.
Old 04-12-2016, 11:36 PM   #824
Algreen
Guest
Posts: n/a
1) the soldered fuse is the setup for the new systems. It works great. Look at my install video for where you install it at. But I believe it 5 slots from the front of the car closest to the center of the vehicle.
2) if rob is suggesting the pc680s use Em. Make sure you get them with the metal jackets.
3) I use the oft to keep track of my afr. I sometimes hit the 11s but I'm running An aftermarket intake.
Thanks. I watched your video, and will check for the location of a switched fuse.
I bought the regular PC680, not the metal jacket. Time will tell on their response to heat.
I think high 11's AFR is the right range. Thanks for the tips!
Old 04-13-2016, 12:01 AM   #825
Sojhinn
Sojhinn's Avatar
If you are using my map you need to set the fuel control. Otherwise something is going on. If you are using the audio plug adapter I would get rid of it and solder the throttle wire.
Installed Mods:
Old 04-13-2016, 08:48 AM   #826
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Well, after driving last night and horsing around before going into work this morning....I can still say the ESC is the best bang for buck when adding power to a DD. I am really amazed that more car companies havent developed more technology along the lines of an ESC.
But I dont DD my BRZ much. I track it more than anything. I have two AX coming up. If i can find a weak spot in the ESC I will let everyone know. The AXs will be a bit different, as they will allow for 2 lap sessions. So this would be about 2 mins or more of continuous hard driving. I think the ESC is up to the task, but I will report back.
Daily: Audi TT RS
keen as (04-14-2016), Sojhinn (04-13-2016)
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
