Old 04-12-2016, 03:50 PM   #225
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
No need to download new tune files if running E85, correct?
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 04-12-2016, 03:55 PM   #226
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Yea no hp difference for E85 only optimized for 93..Still corn life over here
Old 04-12-2016, 04:05 PM   #227
ryoma
ryoma's Avatar
is this OFH release the one that the original post was made for, or will there be another release for non-OFH UEL headers?
Old 04-12-2016, 04:29 PM   #228
BurnetRhoades
BurnetRhoades's Avatar
Drives: 2013 "Hot Lava"
Thread title and initial posting indicates UEL in a general sense, with reference to OFH at the very bottom regarding some tweaks to VVT. Is this change specific enough to be incompatible with JDL?
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
BurnetRhoades is offline   Reply With Quote
Old 04-12-2016, 04:48 PM   #229
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
I second this question, is the updated tune specific enough to the OFH to be incompatible w/ any typical aftermarket UEL header? @Shiv@Openflash
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 04-12-2016, 04:57 PM   #230
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi guys,
The VVT tables are optimized specifically for the OFH. I cannot predict how it will work with other headers. I wouldn't say that they are incompatible with other headers. All I can say is that they may not be optimized. These maps are pretty aggressive so please don't treat them like any other OTS map.
Shiv@Openflash is offline   Reply With Quote
Old 04-12-2016, 04:58 PM   #231
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by Shiv@Openflash View Post
Hi guys,
So for those with JDL UELs keep using the VVT maps you posted before but maybe take advantage of some of the other changes/tweaks you've implemented?
Old 04-12-2016, 04:59 PM   #232
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I understand supporting your product first (OFH) and have no problem with that. I also understand that there's an exponentially large amount of aftermarket setups, but my question is: are there plans to have similar optimizations for other headers such as JDL, Borla, Tomei?
Jyn is offline   Reply With Quote
Old 04-12-2016, 05:09 PM   #233
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
Hoping for some feedback from jdl uel users that run this tune soon.
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
Old 04-12-2016, 05:23 PM   #234
ryoma
ryoma's Avatar
Hi guys,
will there be similar optimizations to the tunes with other aftermarket UEL headers aside from OFH coming in the future? or will you be specifically supporting OFH tunes?
Old 04-12-2016, 05:39 PM   #235
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
How much more aggressive are these tunes? Do you recommend that we have the oft reading out on the dash at all times, or do you mean we simply check up on it more often than the current tunes? How much room in these is there for knock correction as opposed to the previous tune?
Sent from my Glade Air Freshener
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 04-12-2016, 06:09 PM   #236
WRBrzRX
Drives: runs&drives
He said flat out, he doesn't know how it will work on other headers. OFH users were asked for specifically in the beta test. We're going to have to test it and give feedback to each other.
WRBrzRX is offline   Reply With Quote
Old 04-12-2016, 06:43 PM   #237
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Hi guys,
Shiv can you clarify what we should specifically datalog? i.e. which Data channels?
Old 04-12-2016, 07:05 PM   #238
jvincent
jvincent's Avatar
For those of you who haven't checked in RomRaider yet, there are 12 tables that have changes when you compare the OTS tunes to the OFH optimized tune. They are:
Primary open loop fueling
Engine Load Limit B Maximum (RPM)
Engine Load Limit C Maximum (RPM)
Base Timing B
Knock Correction Advance Max A
Timing Compensation (IAT)
Timing Compensation Per Cylinder A
Timing Compensation Per Cylinder B
Intake Cam Advance Angle Safe AVCS
Intake Cam Advance Angle Normal AVCS
Exhaust Cam Retard Angle Safe AVCS
Exhaust Cam Retard Angle Normal AVCS
What does all of this mean? Just that the tunes are different. When you look at the areas you'll see that the changes are designed to go together since many of them are in the same general RPM/load area.
Using these with a different header will clearly be a YMMV situation. If you are looking to try them out just go ahead and log the data.
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
