Old 04-06-2016, 03:06 PM   #15
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
@MisterSheep Nope, I did not have any noticeable changes in sound (except a lack of grinding). My gearbox does whine a little bit, when changing into second or (mainly) first while rolling, but it also did that before the fluid change and it's not loud.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
The Following User Says Thank You to Keenercarguy For This Useful Post:
MisterSheep (04-06-2016)
Old 04-06-2016, 03:09 PM   #16
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
ah okay, because in my last trans I had it changed to motul but I then noticed the trans being extremely loud and whinny a couple thousand miles later and the dealership warrantied the trans. just been iffy about going back and paying to change the fluid again..
Instagram: trevor.parque
Old 04-06-2016, 03:16 PM   #17
Keenercarguy
Mountain Runner
Gotcha, well one of the best things about Motul is that they integrate a flexible hose into their bottle so you can actually change the fluid yourself pretty easily with just jack stands and hand tools
Old 04-06-2016, 03:21 PM   #18
shellslinger
Drives: Whiteout FRS
After changing to Motul I got a loud knocking noise from my transmission at idle when its cold. But it goes away when its warmed up. Also, 2nd gear grind went away after fluid change.
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
Old 04-06-2016, 03:24 PM   #19
MisterSheep
Killed Scion
That's your throw out bearing making noise. It happens to everyone basically, but I also noticed it was more audible when switching to motul.
Old 04-07-2016, 10:52 AM   #20
Silver86K
Drives: Silver 86
Here is the noise I am getting now all of a sudden, never had any problems, got a 2012 model, manual, on start up now, there is this scratching sound if I depress the clutch like 5mm in and once fully in it also makes a noise, tried getting a video of it but it just doesn't come across like it does in person.
New findings, this morning my car had stood outside overnight and the last two nights is the first time it has been prettt cold, came back home now, car standing in a relatively warm garage and went to start her up to see if it is still there, and now it is very faint, very weird, will monitor over weekend and maybe take to dealership if it still is bad by Monday
Silver86K is offline   Reply With Quote
Old 04-07-2016, 12:31 PM   #21
Zyo81
Drives: '13 Firestorm FR-S, 99 Mustang GT
My car ground 2nd a lot when I first got it. I had to skip to 3rd a lot. If I remember right about 18k it started acting a lot better. This was only when cold of course, when warm it always acted fine. Still using OE fluid.
Zyo81 is offline   Reply With Quote
Old 04-07-2016, 01:47 PM   #22
Am I the only guy that has never had any issue at all with second? I just mentioned in the starting problems thread how I was baffled how some of these cars have issues and others do not. I have not once experienced any shifting problems even when very cold (I have zero incentive to lie about this) and am over 60K miles on the original tranny oil.
Ultramaroon (04-10-2016)
Old 04-07-2016, 01:50 PM   #23
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
I just smoothly shift it (methodically) to second till it warms up then its okay to shift whatever gear
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
The Following User Says Thank You to RichardsFRS For This Useful Post:
Tcoat (04-07-2016)
Old 04-07-2016, 02:52 PM   #24
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Never had issues either. But then again I tend to drive above 4k RPM all the time, heh.
The Following User Says Thank You to PandaSPUR For This Useful Post:
Tcoat (04-07-2016)
Old 04-10-2016, 10:00 PM   #25
cjd
cjd's Avatar
Drives: 2017 BRZ
No. I've come to the conclusion that many people simply don't have the ability for muscle memory, so their movements are just not as precise and they miss the gate. I'd add to that the possibility that their sense of timing is similarly lacking, so while they insist the cluch is in, it may not be...
This conclusion is the result of a sample size of one, but... it would only take a very little bit of either scenario to cause 2nd to be crunchy, and that kind of problem only gets worse as you pound at it.
I admit, my transmission is picky when cold about 2nd, but it's very easy to work with. I also occasionally have to put it in 2nd to get it into 1st at a dead stop when it's cold. It seems to be a transmission designed to be somewhat precise and not too sloppy; a little variance in assembly could easily account for relative levels of pickiness, but...
The Following User Says Thank You to cjd For This Useful Post:
Tcoat (04-10-2016)
Old 04-10-2016, 11:42 PM   #26
tumbla.jr
taicho
tumbla.jr's Avatar
Drives: The rEd Fr-S
Did you get any loud whinning noises after switching to Motul?
I did.
tumbla.jr is offline   Reply With Quote
The Following User Says Thank You to tumbla.jr For This Useful Post:
MisterSheep (04-10-2016)
Old 04-10-2016, 11:49 PM   #27
MisterSheep
Killed Scion
Originally Posted by tumbla.jr View Post
I did.
Like what kind of noises?
Old 04-10-2016, 11:52 PM   #28
tumbla.jr
taicho
tumbla.jr's Avatar
High pitched whine under partial load but only at speeds above 60.
Prior to changing from redline last week I could barely hear anything from my transmission.
Diff and trans were pretty dirty after 45K
Anyone still have gear grinding issues? goshem Engine, Exhaust, Transmission 52 10-01-2015 06:51 PM
5th gear grinding Bernie Issues | Warranty | Recalls / TSB 1 05-15-2015 08:10 AM
6th gear grinding D-VO Issues | Warranty | Recalls / TSB 59 04-07-2015 02:26 PM
Grinding in 3rd gear...what's going on?! hozouria Engine, Exhaust, Transmission 3 08-13-2014 02:31 PM
6th Gear Grinding KpAtch3s Issues | Warranty | Recalls / TSB 0 06-18-2013 08:07 PM
