Old 09-26-2015, 03:48 AM   #1
goshem
goshem's Avatar
Drives: 16' WRX
Anyone still have gear grinding issues?
So I bought this car at the beginning of 2014. I love the car, however since I got it, 2nd gear and 5th gear grinds like crazy. 2nd gear just seems like it's crunchy no matter if I let it warm up or not. It mostly doesn't grind but just seems hesitant to get into 2nd, and would almost 99% of the time make a crunchy noise. 5th gear is usually a hit or miss, I would have days with it being perfect and days where it would grind more than once in a trip. At the end of 2014 I brought the car back to the dealer where I bought it and they tested it out and says "normal, nothing out of the ordinary," so I thought maybe I'm not driving the car right. I swapped out the tranny fluid to Motul, but the problem STILL persists. This transmission is bugging the crap out of me at the moment to the point where I want to trade cars. I don't know if I should take it in to another dealer and complain more, or call SoA or just last resort trade it in and buy a WRX. Could anyone give me some valuable advice?
Much appreciated!
goshem is offline   Reply With Quote
The Following User Says Thank You to goshem For This Useful Post:
FastWhite (09-27-2015)
Old 09-26-2015, 03:58 AM   #2
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Never
hmong337 is offline   Reply With Quote
Old 09-26-2015, 04:49 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
hesitant to get into 2nd when cold started until gearbox warms up slightly - common for all. No problems soon after, and it just takes a bit more effort to get into 2nd, not accompanied by any extra mechanical noise.
As for rest, never experienced such. Grind at 2nd & 5th .. maybe synchros issues? Maybe clutch not disengaged fully when switching gears?
Old 09-26-2015, 06:30 AM   #4
RIP.S2000
RIP.S2000's Avatar
Drives: 2015 BRZ Series.Blue, ('00 S2000)
Exactly how it is for me. Hasn't grinded for me at all.
Sent from my SAMSUNG-SM-N910A using Tapatalk
RIP.S2000 is offline   Reply With Quote
Old 09-26-2015, 07:57 AM   #5
Tekno Virus
Drives: 2015 Subaru BRZ Limited
I gotta admit, this transmission is pretty hard to drive with.
Tekno Virus is offline   Reply With Quote
Old 09-26-2015, 09:30 AM   #6
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
A friend with a 2015 FRS has this issue. We both are ready to replace the clutch as we both feel the factory clutch is at fault. I personally don't have anything nice to say about the toilet paper clutch that I removed when I upgraded to a turbo and a heavy duty clutch installed. Even at 10k miles I had massive dust everywhere with light driving.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 09-26-2015, 10:31 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Imho for stock NA power stock clutch is adequate. And did i say 'maybe clutch gone bad'? Just that maybe it's not fully disengaged for whatever reason, try yourself switching gears with not pressing clutch all the way (which can often happen for ones driven manual less) with loud mechanical grind noise as result
Old 09-26-2015, 12:12 PM   #8
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Goshem! Go and get your transmission replaced under warranty.
Had that same 5th gear crunch almost every time i shifted - with the clutch fully flat on the floor. It hurt my soul every time i shifted..
Took it to the dealers, less than 5 minutes and they said the tranny needed swapped.. Car had 14,000 miles. Its a factory known malfunction in the tranny and MANY of us have had to go in and get a tranny swap. Good thing is its FREE and you get a free rental for a week that you can take to your local auto x event..
Edit: Just read that you already took it to the dealers.... Sounds like a shady group or they don't know what they are doing if they wont replace it.. Try a different dealership..
olsonpg is offline   Reply With Quote
Old 09-26-2015, 01:16 PM   #9
Xuningshen
Drives: Subaru BRZ
I understand there are legit transmission issues out there. but because our shifter mechanism is all levers(is that the right word?) and not cables, you get to feel everything going on in the transmission, the syncros speeding up or slowing down etc. I actually really like that. I've always wondered if people were mistaking that for the crunch though. 2014 here and i quite like my transmission to the point where i'm downshifting and rev matching, and heel toe'ing, during my daily commute haha.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
The Following 2 Users Say Thank You to Xuningshen For This Useful Post:
Tcoat (09-27-2015), TheVoiceOfReason (09-26-2015)
Old 09-26-2015, 02:23 PM   #10
humfrz
Originally Posted by goshem View Post
........................ so I thought maybe I'm not driving the car right............... Could anyone give me some valuable advice?
Much appreciated!
This is all I got.
I would suggest that when shifting, wind up the last gear pretty tight (>4,000 rpms) before shifting into the next higher gear.
Also, when shifting from 1st to 2nd, pull the shift lever slowly and firmly into 2nd gear ....... same for 4-5 (except push it .....).
It's not a toggle switch ..... the lever is moving heavy transmission parts.
I suggest you not "lazy leg" it and push the clutch pedal all the way to the floor.
If these techniques don't help, you may consider bleeding the clutch system and/or adjusting the clutch.
humfrz
Tcoat (09-27-2015)
Old 09-26-2015, 05:26 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
humfrz: yes, rev matching will often help and reduce load on gearbox/synchros .. but imho no grinding should be heard even without rev matching on properly working clutch and gearbox. Not always it's driver fault, sometimes really there can be mechanical issue
Old 09-26-2015, 06:18 PM   #12
humfrz
That's true ...... however, eliminating pilot error is an easy and economical thing to try .....
Yep, driving a MT car when gear changing is a "grind" is no fun.....
Y, I remember, back in the day, when a transmission had a bad 2nd gear synchronizer, we would gently nudge the shift lever up towards 2nd till the grinding subsided, then push it into gear ......
It MUST be my nap time ......
humfrz
Tcoat (09-27-2015), Ultramaroon (09-26-2015)
Old 09-26-2015, 06:52 PM   #13
swarb
Much appreciated!
Why did you wait so long to do something?
Why did you wait so long after taking it to the dealer to finally post this and ask for advice?
Is this your first manual transmission car?
Take it to another dealer.
Buy an automatic.
Old 09-26-2015, 09:22 PM   #14
humfrz
Buy an automatic.
DANG, @swarb ....... are you off your meds ..... again .... ?? .....
humfrz
fika84 (09-27-2015), Ultramaroon (09-27-2015)
*UPDATE FROM TOYOTA REP*: Regarding 4th and 5th gear grinding issues... husker741 Issues | Warranty | Recalls / TSB 97 08-27-2015 10:46 AM
5th gear grinding Bernie Issues | Warranty | Recalls / TSB 1 05-15-2015 07:10 AM
6th gear grinding D-VO Issues | Warranty | Recalls / TSB 59 04-07-2015 01:26 PM
Grinding in 3rd gear...what's going on?! hozouria Engine, Exhaust, Transmission 3 08-13-2014 01:31 PM
6th Gear Grinding KpAtch3s Issues | Warranty | Recalls / TSB 0 06-18-2013 07:07 PM
