Old 04-10-2016, 12:25 AM   #1
lupindub
Drives: Scion FR-S
Are my wheels improperly balanced?
So I just bought a used set of wheels from a member on this forum and when I opened the package and inspected the wheel, lo' and behold one of the wheel's had 35 + wheel weights on them.
Now i'm no expert on this subject but this seems a bit excessive. Not only is there a lot but the locations they are put on leaves me scratching my head. For example, in the picture you can see that the wheel weights are PARALLEL to each other instead of being clumped up on one side. Wouldn't putting wheel weights on parallel side defeat the purpose of BALANCING the wheels?
I also found a patch where the wheel weight's are stacked on top of each other - not sure if this is normal or not. All in all am I being paranoid or should I go get them re-balanced properly?
lupindub is offline   Reply With Quote
Old 04-10-2016, 12:27 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
scrape off all the weights.
Also look for damage. If there is excessive wheel weights it was probably hard to balance. Might have been bad tires also.
Old 04-10-2016, 12:31 AM   #3
Don't remove them. Find a seasoned pro and let him/her see the current setup before completely rebalancing. It's good information.
And no, that ain't right.
Old 04-10-2016, 12:40 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
There are no tires on those wheels
The Following User Says Thank You to ZionsWrath For This Useful Post:
Ultramaroon (04-10-2016)
Old 04-10-2016, 02:06 AM   #5
So yeah, like I was saying, just scrape them off.
Now if you'll excuse me, I'll just take a seat over there ------>
Tcoat (04-11-2016)
Old 04-10-2016, 02:40 AM   #6
lupindub
Drives: Scion FR-S
Am I being dull here or what is the reason you guys recommend removing the weights? Won't the tire shop pull 'em off before re-balancing anyways?
Old 04-10-2016, 02:45 AM   #7
They will. I was just trying to joke my way out of the stupid zone.
Old 04-10-2016, 02:47 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
True but they are going to spend zero time cleaning up the wheels. I'd remove em and clean the areas with your preferred cleaner.
Also the wheels have no tires on them so it's hard to say why the weights are like that.
So yes you could just take it to a shop with a set of tires and tell them to mount and balance them.
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
lupindub (04-10-2016), Ultramaroon (04-10-2016)
Old 04-10-2016, 02:49 AM   #9
lupindub
Drives: Scion FR-S
Previous owner took the tires off before shipping. So it was mounted and balanced by some animal at some point.
Old 04-10-2016, 03:52 AM   #10
dvasqu01
dvasqu01's Avatar
Drives: Scion FRS Whiteout
Previous owner took the tires off before shipping. So it was mounted and balanced (by some animal) at some point.
Part in parentheses made me giggle 😂
dvasqu01 is offline   Reply With Quote
Old 04-10-2016, 10:02 PM   #11
lupindub
Drives: Scion FR-S
Just pulled these off my wheels:
The Following User Says Thank You to lupindub For This Useful Post:
ZionsWrath (04-10-2016)
Old 04-10-2016, 11:43 PM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
Broken pics
Old 04-10-2016, 11:50 PM   #13
lupindub
Drives: Scion FR-S
Broken pics
They should be up by tomorrow morning. I forgot to back them up on Google Photo's.
Ultramaroon (04-11-2016)
Old 04-11-2016, 03:48 PM   #14
8R6
8R6's Avatar
Drives: FRS
cool
8R6 is offline   Reply With Quote
Fluidampr Internally Balanced Damper MAPerformance Engine, Exhaust, Transmission 29 08-20-2017 11:40 PM
Engine swap that will improve the car in a balanced way? DVNARC Scion FR-S / Toyota 86 GT86 General Forum 2 09-04-2015 02:01 AM
perfect balanced wheels BRZtoni Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-06-2014 12:27 PM
Dealer Improperly Mounted Front Plate cluckinrooster Scion FR-S / Toyota 86 GT86 General Forum 9 04-18-2014 12:20 PM
Got Corner Balanced and Aligned track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 08-10-2012 01:35 PM
