Old 06-08-2015, 04:11 PM   #1
MAPerformance
Drives: Asphalt FRS
Fluidampr Internally Balanced Damper
Another cool products was released today from Fluidampr. Pretty interesting stuff. Testing revealed consistent performance gains above 4000rpm compared to both an OEM tuned elastomer damper and a lightweight crankshaft pulley. The lightweight pulley tested provided no torsional vibration protection and left internal components susceptible to potentially destructive high frequency vibration between 5,000 - 7,000rpm.
This may be a good investment for people running built motors, or cars that see a lot of high RPM track time. Good piece of mind mod.
MAPerformance is offline   Reply With Quote
Old 06-08-2015, 06:03 PM   #2
celek
Resident Gear Head
celek's Avatar
I thought they released this like 6 months ago or is this revised.
I would also like to know if the graphs are FA20 specific because those TQ and Power numbers do not look right
celek is offline   Reply With Quote
Old 06-08-2015, 06:37 PM   #3
MAPerformance
Drives: Asphalt FRS
I am not sure what dyno they used. I thought it looked weird too, but they started the graph 4k rpm, so the torque dip is not visible.
Old 06-08-2015, 06:57 PM   #4
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Thank god someone else posted this! People on here will have a field day with the theory of boxer engines being "naturally balanced" and are convinced that light weight pulley will not harm their engine! Thank you. I got flamed hard for posting a thread for a brand of performance crankshaft harmonic balancers.
Gords_zenith is offline   Reply With Quote
Old 06-08-2015, 08:06 PM   #5
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
I have one of these for my GTI I'm building the motor on, it's a nice product for sure. Not sure how that translates to the boxer motor though lol.
*mod list*
Lawn_Mower is offline   Reply With Quote
Old 06-09-2015, 10:46 AM   #6
fika84
fika84's Avatar
+1 that graph looks off.. and they need to show the entire RPM range unless they are hiding something.
@MAPerformance is the frequency graph for the FA20?? Or just some graph they have laying around?
fika84 is offline   Reply With Quote
Old 06-09-2015, 11:57 AM   #7
MAPerformance
Drives: Asphalt FRS
That one was an actual FA20 from either an FRS/BRZ that they tested. They also released one for the Evo X, and had a specific dyno for that vehicle as well. I reached out to them to see if they can give us the full dyno graph.
Old 06-09-2015, 04:22 PM   #8
MAPerformance
Drives: Asphalt FRS
Got a response back with a full dyno, as well as both waterfall plots of the torsional vibration testing, which measures the overall twist (peak-peak) resonance of the crankshaft running the Fluidampr, OEM damper, and a lightweight pulley.
The car tested was a 2013 FRS with an intake, single exhaust, and a tune done at R/T Tuning on a Mustang Dyno.
Old 06-09-2015, 05:16 PM   #9
mkivsoopra
No wonder the initial graph started at 4000... didn't want to show the drop from 2800 to 3500 RPM. What's going on there?
mkivsoopra is offline   Reply With Quote
Old 06-09-2015, 05:21 PM   #10
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Probably because it's heavier than the stock pulley
ScionOfHorus is offline   Reply With Quote
Old 06-09-2015, 05:40 PM   #11
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Would someone be so kind as to make comment on the 3 waterfall graphs? I don't know if any of what has been shown is good or bad.
Old 06-09-2015, 05:53 PM   #12
fika84
fika84's Avatar
I don't know what the "orders" or the "peak vibration angle" is referring to.. it might have to do with the sensor that they are using to measure the data.
Old 06-09-2015, 06:03 PM   #13
MAPerformance
Drives: Asphalt FRS
Most likely correct. He did mention that they typically focus on high RPM performance since most customers use these for high RPM use, mainly track cars. But yes, very interesting indeed.
Old 06-09-2015, 06:23 PM   #14
GhostOp86
Fr-s Whiteout
GhostOp86's Avatar
Drives: 2017 civic type R #1353 2017 ss1le,
Turbo Fr-s 2013 Cam Tuning SOLD
http://youtu.be/3vM-2MijcQQ
2017 ss1le
2017 Honda Civic Type R #1353
2002 Rsx Type s
GhostOp86 is offline   Reply With Quote
Fluidampr Damper Pulley 571101 Sale!! Mike@CZP Engine, Exhaust, Bolt-Ons 156 06-01-2018 12:24 PM
Brand New FRS/BRZ Tires and Rims (mounted, balanced) Hamza7 Canada Classifieds 1 05-16-2015 01:12 PM
perfect balanced wheels BRZtoni Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-06-2014 11:27 AM
FS: RS*R Sports-i coilover (corner balanced) RYU Brakes, Suspension, Chassis 27 01-09-2014 11:51 AM
Got Corner Balanced and Aligned track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 08-10-2012 12:35 PM
