Old 03-27-2016, 07:13 PM   #15
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
In for updates. Sorry about your baby.
Make sure to tell the service dept. not to wash your car.
Originally Posted by humfrz
I'm old and lazy
Old 03-27-2016, 07:31 PM   #16
cjd
cjd's Avatar
Drives: 2017 BRZ
It almost sounds like the issue I had with the exhaust rubbing in the rear subframe... Though mine also needed a somewhat high engine load (so accelerating or going up a hill) but... Well, you looked at that.
Hopefully it's nothing serious.
Old 03-27-2016, 07:48 PM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
Yes, it would be interesting to hear actual cause. And whose guess was closest to it
P.S.
Stupid idea .. do vibrations happened only when driving, or also when free revving? In 2nd case i'd try to put it on ramp and someone below hearing while it's get revved. Or rize rear end and try to rew it in gear .. but yet again in similar fashion someone watching/hearing below, where it's easier to locate sound source ..
Old 04-02-2016, 03:22 AM   #18
Kostamojen
Well the throwout bearing was replaced under warranty, but nothing could be found in regards to the vibration and they blamed it on the transmission mount insert and the shifter bushing... (Both of which I've changed AFTER getting the vibration).
I'll have to try removing the insert and maybe swapping engine mounts to see what that does.
Does anybody else find the traction control to be too harsh? JoshMonster BRZ First-Gen (2012+) — General Topics 64 04-06-2016 05:13 PM
Shrill/harsh tweeters customyota Electronics | Audio | NAV | Infotainment 21 07-21-2015 03:37 PM
Stock Header with 3000 miles The Racers Line Engine, Exhaust, Bolt-Ons 8 06-20-2014 03:19 PM
stock BRZ wheels/tires 3000 miles. Mobile,AL zumin Wheels and Tires 2 04-15-2014 01:34 AM
Is 18 x 7 too narrow Abflug Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-12-2012 11:43 AM
